UPDATE Re: C# Mapscript ASP.NET Deployment Problem
Tamas Szekeres szekerest at GMAIL.COM
Sun Dec 2 17:44:34 EST 2007
Bruno,
I've added AllowPartiallyTrustedCallers in the trunk, but I haven't
found any compilation issues.
You can see the results at the mapserver buildbot:
http://buildbot.osgeo.org:8504/waterfall
The binaries for testing purposes can be downloaded from here:
http://vbkto.dyndns.org:1080/mapserver/szekerest-vc71-full/package/bin.zip
http://vbkto.dyndns.org:1080/mapserver/szekerest-vc80-full/package/bin.zip
http://vbkto.dyndns.org:1080/mapserver/szekerest-vc80x64-full/package/bin.zip
Notify me how it goes.
Best regards,
Tamas
2007/12/2, Bruno Gendron <bruno_gendron at yahoo.com>:
> Tamas,
> I added to [assembly:AllowPartiallyTrustedCallers] to the assembly
> configuration file, then tried to compile mapscript, with no success. SWIG
> is still producing the following error:
> ..\..\mapserver.h(1393): Error: Syntax error in input(1)
> I'm using mapserver.h from CVS (attached to this message).
> I'm using VS 2003.
> On Fri, 30 Nov 2007 19:41:00 +0100, Tamas Szekeres <szekerest at GMAIL.COM> wrote:
> >Bruno,
> >I guess your deployment configuration would require to add the following line:
> >in mapscript\csharp\config\AssemblyInfo.cs
> >You can add this row and recompile the csharp bindings to see whether
> >this fix solves the problem or not.
> >However I've never run into this problem. Could you describe the steps
> >in a ticket to reproduce this behaviour?
> >http://trac.osgeo.org/mapserver/newticket
> >Best regards,
> >Tamas
