Antwort: [UMN_MAPSERVER-USERS] Oracle spatial performance issue
Benedikt Rothe
umn-ms at HYDROTEC.DE
Wed Dec 5 03:38:43 EST 2007
Hi
> By adding the keyword /*+ ordered */ to the select statement
considerably
> speeds up the quary. The resulting SQL statement the looks like this:
> SELECT /*+ ordered */OBJECTID, OBJTYPE, SHAPE FROM
KARTDATA.N50_HoydeKontur
What about this?
LAYER
NAME "N50Hoydekurver"
DATA "SHAPE FROM (SELECT /*+ ordered */ OBJECTID, OBJTYPE, SHAPE FROM
KARTDATA.N50_HoydeKontur) USING UNIQUE OBJECTID VERSION 10g"
Benedikt Rothe
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
04.12.2007 09:33:29:
> Hi!
> I have set up a mapfile with layers that uses oracle spatial data. The
> problem is that the performance is rather bad. This is how I have set up
the
> connection in the LAYER object.
> LAYER
> STATUS ON
> CONNECTION "user/pass at KARTINNS_SKRIVDB06"
> CONNECTIONTYPE oraclespatial
> DATA "SHAPE FROM KARTDATA.N50_HoydeKontur USING UNIQUE OBJECTID
> VERSION 10g"
> When this layer is queried the resulting SQL that is submitted to the
> database typically looks like this:
> SELECT OBJECTID, OBJTYPE, SHAPE FROM KARTDATA.N50_HoydeKontur
> WHERE SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.
> SDO_ORDINATE_ARRAY(-26711.6293,6726071.91,-14068.0091,6736415.72)
> ),'querytype=window') = 'TRUE'
considerably
> This test is performed manually because I haven't find anywhere to
insert
> the keyword in the mapfile. Anyone have any ideas on how I could
accomplish
> to tell MapServer to insert the keyword before sending the SQL to the
> database?
> regards,
> Pål Kristensen
> View this message in context: http://www.nabble.com/Oracle-spatial-
> performance-issue-tf4941783.html#a14146626
> Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071205/5c979e6c/attachment.html
