Rendering glitches with MS 5.1-devel
Gregor Mosheh
gregor at HOSTGIS.COM
Wed Dec 5 15:19:20 EST 2007
I'm having some rendering glitches with Mapserver 5.1-dev
Go to http://69.59.158.8/ and let the map load.
There is no need to zoom in, nor to pan anywhere in particular, to see
the issues.
* Satellite: has that big black rectangle to the south, and the green
corners of a rectangle. This doesn't happen under 5.0.0
* Interstate Highways: Some of the shields are faded and odd looking.
This does happen under 5.0.0 I do notice that the shields are ones which
corss tile boundaries, maybe that's the issue?
* Base: There's a very visible rendering glitch over Minnesota and
Michigan, and over New England. This doesn't happen under 5.0.0
The map is using AGG/PNG for all layers.
I'm using the dev because this map uses TrueType symbols, and those are
known not to work in MS 5.0.0 The svn version does fix that error, but
seems to introduce these new ones.
Any ideas?
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
