Google Earth
Milo van der Linden mlinden at ZEELANDNET.NL
Fri Dec 7 11:59:27 EST 2007
Hans Castorp schreef:
> Thanks for fast replying,
> Do you mean set this metadata in every layer section???
> I made it and had no success.
No, it is the metadata set in the MAP's WEB section. There you have to
alter it.
> PS. I have a projection section in this way:
> PROJECTION
> 	"init=epsg:23029"
> END
That is correct. Every layer can only have one PROJECTION. The MAP
itself can also only have one projection. But when you set more then
one  "wms_srs"  for instance "EPSG:4326 EPSG:28992" then Mapserver will
reproject before sending the image to the requestor. (I think this is an
excellent function). It needs the PROJECTION sections to determine how
to reproject.
> -----Mensaje original-----
> De: Travis Kirstine [mailto:traviskirstine at gmail.com]
> Enviado el: viernes, 07 de diciembre de 2007 14:31
> Para: Hans Castorp
> CC: MAPSERVER-USERS at lists.umn.edu
> Asunto: Re: [UMN_MAPSERVER-USERS] Google Earth
> Do you have the correct projection set in your metadata?
> METADATA
>    "WMS_SRS" "EPSG:4326"
> END
> On 07/12/2007, Hans Castorp <hanscastorp76 at yahoo.es> wrote:
>> Hi to all,
>> It's possible to visualize wms layers from mapserver using Google Earth??
>> I'm trying to do it but I'm always receiving an error saying that the wms
>> server does not have layer that google earth could process. I think this
>> could be something about my map file configuration. Is there any trick??
>> PD: I'm serving GeoTiff and shape layers.
>> Thanks in advance.
>> Hans Castorp
>> No virus found in this outgoing message.
>> Checked by AVG Free Edition.
>> Version: 7.5.503 / Virus Database: 269.16.17/1176 - Release Date:
> 06/12/2007
>> 23:15
Milo van der Linden
skype: milovanderlinden <skype:milovanderlinden?add>
mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie in dit bericht reflecteert mijn persoonlijke mening en
niet die van een bedrijf of instantie. Aan de informatie kunnen geen
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bij het betreffende
medium behorende voorwaarden. The information in this message reflects
my personal opinion and not that of a company or public body. All rights
reserved.If this message is contained in a mailing-list or community,
the rights on the medium are automatically adapted.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071207/046a4ecc/attachment.html
