issues with scale in wms raster layers
Travis Kirstine
traviskirstine at GMAIL.COM
Tue Dec 11 16:40:37 EST 2007
Try setting your map resolution to 96 DPI the default is 72
RESOLUTION 96
Travis
On 11/12/2007, Smith, Michael <Michael.Smith at maine.gov> wrote:
> I am trying to set up a WMS on MapServer to provide an image catalog to
> ArcGIS users (I am running latest release of MS4W on a Windows XP SP2
> box). The problem I run into is odd behavior with setting scale
> thresholds. I see two issues:
> 1) When I set a MAXSCALEDENOM or MINSCALEDENOM property for my layer,
> the number I put it in there is not the actual min/max scale that is
> shown in ArcGIS. Instead the scale threshold shown in ArcGIS is 4/3 the
> number I have in my .map file. For example if I want my scale threshold
> in ArcGIS to be 50,000, I have to put 37,500 in my .map file.
> 2) I have 3 layers in my .map file, two are external overview images I
> created with gdalwarp (following the steps outlined in
> http://mapserver.gis.umn.edu/docs/howto/raster_data) and the third a
> raster catalog with a tile index. My .map file is below. The problem
> here is that if I use the MINSCALEDENOM and/or MAXSCALEDENOM in my layer
> property for the catalog, and I include the overview images, then my
> raster catalog does not render (it shows in the layer list in my client,
> but nothing but white draws. If I remove the overview layers from my
> .map file and try again, my catalog will work fine and honor the scale
> thresholds I set (once I adjust them as in #1 above). If I remove the
> catalog, the two overviews work correctly. Just not all 3.
> Clients I am using include ArcGIS 9.2 and Quantum GIS 0.9. I see the
> behavior in both.
> Any suggestions? Are there WMS-specific tags I should use in my
> METADATA section instead?
> Michael Smith
> Maine DEP/OIT
> # Start of GMAP map file
> NAME NW_DOQS
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT 396000 5093000 501000 5261000
> UNITS METERS
> SHAPEPATH "../nw_doqs"
> IMAGECOLOR 255 255 255
> FONTSET ../etc/fonts.txt
> OUTPUTFORMAT
> NAME JPEG
> DRIVER "GD/JPEG"
> IMAGEMODE RGB
> EXTENSION "jpeg"
> FORMATOPTION "QUALITY=75,PROGRESSIVE=TRUE"
> END
> OUTPUTFORMAT
> NAME PNG8
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> EXTENSION PNG
> IMAGEMODE PC256
> TRANSPARENT ON
> END
> # Start of web interface definition
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> # For WMS
> METADATA
> "wms_title" "nw_doqs"
> "wms_onlineresource"
> "http://csu-eia1pcgis2.som.w2k.state.me.us/cgi-bin/mapserv.exe?map=c:/ms
> 4w/apps/gmap/htdocs/nw_doqs.map&"
> "wms_srs" "EPSG:26919"
> END
> END
> # Projection - required for WMS
> PROJECTION
> "init=epsg:26919"
> END
> # Start of layer definitions
> LAYER
> NAME nw_doqs100m
> MINSCALEDENOM 375000
> METADATA
> "wms_title" "NW DOQs 100m overview"
> END
> TYPE RASTER
> STATUS ON
> DATA overview100.jp2
> PROJECTION
> "init=epsg:26919"
> END
> END
> LAYER
> NAME nw_doqs10m
> MINSCALEDENOM 37500
> MAXSCALEDENOM 375000
> METADATA
> "wms_title" "NW DOQs 10m overview"
> END
> TYPE RASTER
> STATUS ON
> DATA overview10.jp2
> PROJECTION
> "init=epsg:26919"
> END
> END
> LAYER
> NAME nw_doqs
> MAXSCALEDENOM 37500
> METADATA
> "wms_title" "NW DOQs"
> END
> TILEINDEX "nw_doqs_index.shp"
> TILEITEM "location"
> TYPE RASTER
> STATUS ON
> PROJECTION
> "init=epsg:26919"
> END
> END
> END # Map File
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
