issues with scale in wms raster layers
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Wed Dec 12 03:21:01 EST 2007
What happens if you change the order of your layers so that the vector
layer is before overviews in the mapfile?
-Jukka Rahkonen-
> 2) I have 3 layers in my .map file, two are external
> overview images I created with gdalwarp (following the steps
> outlined in
> http://mapserver.gis.umn.edu/docs/howto/raster_data) and the
> third a raster catalog with a tile index. My .map file is
> below. The problem here is that if I use the MINSCALEDENOM
> and/or MAXSCALEDENOM in my layer property for the catalog,
> and I include the overview images, then my raster catalog
> does not render (it shows in the layer list in my client, but
> nothing but white draws. If I remove the overview layers
> from my .map file and try again, my catalog will work fine
> and honor the scale thresholds I set (once I adjust them as
> in #1 above). If I remove the catalog, the two overviews
> work correctly. Just not all 3.
