problem with polar projection : next step !
JS Ubei jsubei at YAHOO.FR
Wed Dec 12 11:07:42 EST 2007
Hi all,
Now, with your help, I ' succeed to correctly display a map with a polar projection from a shape file ....
Now I need to overlay a raster data on the same map .... and occurs the same problem, I think.
You can see the raster file here : http://farm3.static.flickr.com/2262/2105913678_4146b4cf58.jpg?v=0
And the result here : http://farm3.static.flickr.com/2033/2105913676_a612cd7d79.jpg?v=0
What is your opinion ? How I can correctly configure my map ? For information I use the java/mapscript API and the raster file come from a opendap data server trough the gdal library ....
thank you
Jsubei
----- Message d'origine ----
De : Arnd Wippermann <arnd.wippermann at web.de>
À : JS Ubei <jsubei at YAHOO.FR>
Cc : MAPSERVER-USERS at LISTS.UMN.EDU
Envoyé le : Mardi, 11 Décembre 2007, 22h40mn 00s
Objet : AW: [UMN_MAPSERVER-USERS] problem with polar projection
It should be possible to retrieve the data:
http://www.panoramio.com/photo/6431496.
My mapfile have nothing special. I use OpenLayers, therefor the map is
 build
from a couple of tiles and not a single image, but that should not
 cause any
problems.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
Auftrag von JS Ubei
Gesendet: Dienstag, 11. Dezember 2007 11:46
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: [UMN_MAPSERVER-USERS] problem with polar projection
dear all mapserver users,
I'm trying to display a map with the EPSG:3031 projection system.
I use the GSHHS shape for shorelines and I want to see it centered on
 the
antarctic continent.
Below my map file and a link to the resulted image.
As you can shown the problem is a big hole of data around  the pole.
In advance, thanks for your help.
Jsubei
MAPFILE :
MAP
NAME "test_projection"
IMAGETYPE png
SIZE 600 600
STATUS ON
extent -10000000 -10000000 10000000 10000000
PROJECTION
   "init=epsg:3031"
END
OUTPUTFORMAT
        NAME jpeg
        DRIVER "GD/JPEG"
        MIMETYPE "image/jpeg"
        IMAGEMODE RGB
        EXTENSION "jpg"
        FORMATOPTION "QUALITY=100"
END
LAYER
        NAME "GSHHS"
        DATA "/data/www/html/datashape/gshhs_land"
        STATUS   DEFAULT
        TYPE     LINE
        PROJECTION
                "init=epsg:4326"
        END
        CLASS
                COLOR  0 0 250
        END
END
END
result :
http://farm3.static.flickr.com/2417/2100124467_bd9021c724.jpg?v=0
And what I want to obtain :
http://nsidc.org/data/atlas/epsg_3031.html
____________________________________________________________________________
_
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo!
 Mail
http://mail.yahoo.fr
      _____________________________________________________________________________
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail http://mail.yahoo.fr
