Dynamic charting
thomas bonfort
thomas.bonfort at GMAIL.COM
Wed Dec 12 13:13:35 EST 2007
are you using a paletted outputformat (i.e. gif) ?
if so there's a bug that was found
http://trac.osgeo.org/mapserver/changeset/7036/trunk/mapserver/mapchart.c
you basically have to change all occurences of gdImageColorAllocate to
gdImageColorResolve in mapchart.c
cheers,
tb
On Dec 12, 2007 6:17 PM, Murty Maganti <MMaganti at oriongis.com> wrote:
> Hello All
> I am having a strange issue using 'Dynamic charting' in map server. All
> segments of the chart are displayed in same color for some of the charts.
> Map file definition looks like below
> CLASS
> Name "Col1"
> STYLE
> SIZE
> [COLUMN1]
> COLOR 255 0
> 0
> OUTLINECOLOR
> 0 0 0
> OFFSET 2 0
> END #end style
> END # end class
> CLASS
> Name "Col2"
> STYLE
> SIZE
> [COLUMN2]
> COLOR 0 0
> 255
> OUTLINECOLOR
> 0 0 0
> OFFSET 2 0
> END #end style
> END # end class
> CLASS
> Name "Col3"
> STYLE
> SIZE
> [COLUMN3]
> COLOR 0 255
> 0
> OUTLINECOLOR
> 0 0 0
> OFFSET 2 0
> END #end style
> END # end class
> CLASS
> Name "Col4"
> STYLE
> SIZE
> [COLUMN4]
> COLOR 255
> 255 0
> OUTLINECOLOR
> 0 0 0
> OFFSET 2 0
> END #end style
> END # end class
> I have attached how the output image looks like. As can be seen from the
> image, all segments of some of the charts are shown in the same color
> (yellow in this example).
> Another issue is chart symbols are drawn overlapping each other making hard
> to read some of the charts. I can't find how to define not to draw partial
> charts.
> Regards
> Murty Maganti
