labeling along the line
Gagan Bansal
Gagan.Bansal at RELIANCEADA.COM
Fri Dec 14 06:57:27 EST 2007
Yes It is working on widows version MS4W (MS4W - MapServer 4 Windows -
version 2.2.5)
but i am using
OS : RHEL 4.6 AS x86_64
PHP: 5.2.5
MapServer 5.0.0
Regards
Gagan
"Piero Cavalieri" <Piero.Cavalieri at heidi.it>
12/14/2007 05:19 PM
To
<Gagan.Bansal at RELIANCEADA.COM>, <MAPSERVER-USERS at LISTS.UMN.EDU>
cc
Subject
RE: [UMN_MAPSERVER-USERS] labeling along the line
For me it does work. I’m using binaries from MS4W.
C:\Inetpub\Scripts>mapserv.exe -v
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=WMS
_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS
_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS INPU
T=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Cheers
Piero
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Gagan Bansal
Sent: venerdì 14 dicembre 2007 12.04
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] labeling along the line
I have tested in Mapserver 5.0.0 It is not working at all in this
version.
If i include the ANGLE FOLLOW in map file then there is error.
I have another problem also.
Limitation for number of symbols 64,
as i found in forum that it can be increased by changing in mapsymbol.h
file and recompile
#define MS_MAXSYMBOLS 200 /* maximum number of symbols in a symbol file
but still the limit is 64 only, how can i overcome this limit.
Thanks & Regards
Gagan
Gregor Mosheh <gregor at hostgis.com>
12/08/2007 10:12 PM
To
Gagan Bansal <gagan.bansal at RELIANCEADA.COM>
cc
Subject
Gagan Bansal wrote:
> I am using MS4W - MapServer 4 Windows - version 2.2.5.
What MapServer version is that? "mapserv -v"
I think that ANGLE FOLLOW was introduced in 4.10.3 but on our systems it
never worked until 5.0.0
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
The information contained in this e-mail message is intended only for the
use of the individual or entity to which it is addressed. If you are not
the intended recipient, you should return it to the sender immediately.
Please note that while we scan all e-mails for viruses we cannot guarantee
that any e-mail is virus-free and accept no liability for any damage
caused by any virus transmitted by this email.
The information contained in this e-mail message is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you should return it to the sender immediately. Please note that while we scan all e-mails for viruses we cannot guarantee that any e-mail is virus-free and accept no liability for any damage caused by any virus transmitted by this email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071214/154a5ea6/attachment.html
