[Java mapscript] int imageObj.getSize() does not work
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Dec 18 03:37:58 EST 2007
Please file a bug at:
http://trac.osgeo.org/mapserver
Best regards,
Umberto
On Dec 18, 2007 12:07 AM, rich.fromm <nospam420 at yahoo.com> wrote:
> if i have a valid image in an imageObj object:
> - int imageObj.getWidth() returns the expected value
> - int imageObj.getHeight() returns the expected value
> - void imageObj.save(String, null) successfully writes the image to a file
> - byte[] imageObj.getBytes() successfully returns a byte array (whose length
> matches the size of the file above), containing the proper contents of the
> image (i can subsequently dump it to a file and verify).
> however:
> - int imageObj.getSize() always returns 0
> this turns out to not be a big deal. at first i thought i would have to
> query
> the size with getSize(), then allocate a byte[] of the appropriate size,
> then
> populate the byte[] with getBytes().
> however, it is sufficient to just write code like:
> byte[] bytes = img.getBytes();
> if img is the imageObj containing the image. it's not necessary to directly
> query the size, and if i really want to know it, bytes.length will return
> the
> proper value.
> nevertheless, if i'm properly guessing the intention of imageObj.getSize()
> [maybe i'm wrong], this seems like a bug to me.
> i do notice the following in mapscript/doc/mapscript.txt within the
> mapserver-5.0.0 distribution:
> --- begin ---
> imageObj Attributes
> I don't see where this is used. Anyone? --SG
> imageObj Methods
> [getSize() is not listed here]
> --- end ---
> so maybe it's just deprecated.
> - rich
> View this message in context: http://www.nabble.com/-Java-mapscript--int-imageObj.getSize%28%29-does-not-work-tp14375813p14375813.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
