mapserver update
R. Ortner
reinhard.ortner at EDU.FH-KAERNTEN.AC.AT
Wed Dec 19 04:26:26 EST 2007
Sorry but I´ve never done something like installing mapserver before,...
I even don´t know what the php-devel package is.
If u mean the config.log file, there is something like:
configure:11379: checking for PHP/MapScript module options...
configure:11654: checking for location of config.h or php_config.h
configure:11665: result: /usr/include/php/main//php_config.h
configure:11677: checking whether we have PHP3 or PHP4
configure:11691: result: -DPHP4
configure:11694: checking whether we should use PHP's regex
configure:11717: result: no
configure:11740: result: PHP/MapScript module configured.
configure:12018: checking if --enable-runpath requested
configure:12028: result: no
configure:12036: checking if --with-java-include-os-name specified
configure:12057: result: no, autodetected linux
configure:12208: creating ./config.status
Guillaume Sueur-2 wrote:
> maybe you should check the configure output as it can claims for php
> header files. do you have the php-devel package installed as well ?
> R. Ortner a écrit :
>> I tried to replace my /usr/lib/php/extensions/php_mapscript.so but in the
>> mapserver5 folder (downloaded from
>> http://mapserver.gis.umn.edu/download/current/) is no php_mapserver.so in
>> the /mapserver/php3 folder!?
>> Umberto wrote:
>>> In fact now you have the *CGI* version of mapserver installed. But
>>> since you use php mapscript you need to configure, compile and install
>>> php mapscript.
>>> You should be able to do that just by:
>>> mapserver-5-source$ cd mapscript/php3
>>> mapserver-5-source$ make
>>> and then replace with the new php_*.so the old ones picked up in php.ini
>>> HTH,
>>> Umberto
>>> Hi,
>>> I have Mapserver 4.10 installed and tried to install the mapserver
>>> 5.0.0.
>>> I´ve configured the mapserver with
>>> ./configure --with-ogr=/usr/bin/gdal-config --with-wfs --with-proj
>>> --with-postgis --with-gdal --with-geos --with-wmsclient --with-wcs
>>> --with-sos --with-php=/usr/include/php/main/ --with-threads
>>> and then executed the make command.
>>> after copying the mapserv file to my cgi-bin folder where the old one
>>> (from mapserver 4) was I thougtt that I now have mapserver 5 installed,
>>> but when I call the test.php which shows me what version is installed,
>>> it
>>> tells me still Mapserver 4.10.
>>> Is there something special to do to activate the mapserver 5 (i thought
>>> with installing the version 4 the old version should be either
>>> overwritten
>>> or working parallel by calling the new mapserv or the old mapserv (which
>>> I
>>> copied to a subfolder (mapserver4/mapserv).
>>> regards
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 65 58 88 82
> Site web : http://www.neogeo-online.net
View this message in context: http://www.nabble.com/mapserver-update-tp14412963p14413553.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
