Defining a projection for SetProjection()
David Stajan
dls at INFORMGIS.COM
Wed Dec 19 14:06:55 EST 2007
I'm trying to allow my website to change the projections of the map via a user
control. Sounds simple enough using the SetProjection() function!
The problem that I'm having is I can't figure out the proper projection defintion
to define the projection in a PROJ.4 syntax For example I have this projection
defined by a ESRI prj file:
PROJCS["AGD_1966_AMG_Zone_55",
GEOGCS["GCS_Australian_1966",
DATUM["D_Australian_1966",
SPHEROID["Australian",6378160,298.25]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000],
PARAMETER["False_Northing",10000000],
PARAMETER["Central_Meridian",147],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0],
UNIT["Meter",1]]
My best attempt to define this using the proj.4 syntax is:
PROJECTION
"proj=utm"
"zone=55"
"units=m"
"ellps=aust_SA"
"lat_0=0"
"lon_0=147"
"x_0=500000"
"y_0=10000000"
"k_0=0.9996"
"a=6378160"
"rf=298.25"
"pm=greenwich"
END
Can anyone help me out?
Thanks
David
