Zoom to location by name or other parameter using cgi mapserv
Ben Madin
ben at REMOTEINFORMATION.COM.AU
Sun Dec 23 20:50:18 EST 2007
Thanks Richard (& Bob),
On 21/12/2007, at 11:02 PM, Richard Greenwood wrote:
> The trick to getting the query result into your main map is to make
> the TEMPLATE for the query layer be the main map. So in your map file
> the template for 'stops' should be whatever your main map html file
> is.
This was the trick I needed! A little bit of tweaking, and now it is
nearly perfect - so I will endeavour to write something for the howto
site. What would be an appropriate heading for this - "Reverse queries"?
Some other issues that struck me during this process :
Expressions - there used to be a page on this on the MapServer site,
but I can't find it now - is it just me. Subsequent to this -
Validation Patterns - the need for this this snuck past me - I
confess I just installed William Kyngesbury's binaries for 5, without
reading the changes. However, it deserves a special mention for the
useful error message, which give me enough of a hint to be able to
find out what I needed to do!
METADATA
layer_title "Farm Boundaries"
qstring_validation_pattern '\d*'
END
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
ben at remoteinformation.com.au
Out here, it pays to know...
