World Files - Defining Image Rotation
Guillaume Sueur
guillaume.sueur at NEOGEO-ONLINE.NET
Wed Dec 26 10:56:34 EST 2007
After some test, I confirm the right way to write tfw files for rotated
images is the one described here :
http://www.omg.unb.ca/~jonnyb/processing/geotiff_tifw_format.html
which I can sum up with :
first line of tfw file : pixel resolution * cos(rotation angle in radians)
2nd line : -pixel resolution * sin(rotation angle)
3rd line : -pixel resolution * sin(rotation angle)
4th line : -pixel resolution * cos(rotation angle)
5th and 6th lines still x and y of top left corner.
Hope that helps,
Happy holidays to all mapserver-users lists readers
Guillaume Sueur a écrit :
> Hi,
> It doesn't help so much on the precise point of rotation parameters.
> I've had the same problem few days ago, and despite many tests I didn't
> manage to get a proper rotated image. I fixed that with a "solid"
> rotation, set into the image file. But I'm also interested by that approach.
> What are the units of rotation parameters ? I think it's radians, but
> maybe directly cos and sin of angle in radian which would be more
> adequate tu use in the six parameters transformation...
> Is it counter-clockwise (i.e. trigonometric) direction ?
> is the first one x or y rotation term ? The ESRI support page
> (http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=17489)
> is useless.
> the best info I've found are here :
> but I haven't tried yet.
> Guillaume
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 65 58 88 82
Site web : http://www.neogeo-online.net
