Raster Image and Shapefile Alignment
Richard Duivenvoorde rdmailings at DUIF.NET
Mon Feb 5 09:44:51 EST 2007
Hi Bradley,
I managed to georeference some rasters I had using the free tools listed
here:
http://www.forestpal.com/Help/georeference.html
Richard
Bradley Mclain wrote:
> How would you suggest I go about re-doing the georeferencing?
> Brad
>> From: Barend Köbben <kobben at itc.nl>
>> To: Bradley Mclain <bradleym06 at HOTMAIL.COM>
>> Subject: Re: [UMN_MAPSERVER-USERS] Raster Image and Shapefile Alignment
>> Date: Fri, 02 Feb 2007 09:19:33 +0100
>> HI,
>> The shapefile is in an Australian projection, and your raster has been
>> georeferenced to *something*, but there's no telling to what
>> projection they
>> georef'd it, because there's no projection info in the raster file.
>> In other words: someone told the raster "you fit in this place in the
>> world,
>> between XY 1 and XY 2", but they didn't specify in what projection system
>> those XY's are. You would suppose to the same projection the vector is
>> in,
>> and in that case, the fit will be OK as long as the projection of the
>> shape
>> remains the same as it was when the raster was georef'd to it. But if one
>> changes that projection, or maybe only the Datum, as tends to happen
>> unexpectedly when you transfer files from one GIS to another, things will
>> misalign...
>> To make matters worse, it can also just be a case of sloppy
>> georeferencing...
>> Without knowing the rasterprojection, there's no solution, except
>> re-doing
>> the georeferencing...
>> On 02-02-2007 07:16, "Bradley Mclain" <bradleym06 at HOTMAIL.COM> wrote:
>> > Umm I know very little about geodata so i'll simply attach the
>> readouts from
>> > ogrinfo and gdalinfo so you can see for yourself cause i have no
>> idea. :)
>> > If it helps any they are only out slightly. (as shown in attached
>> > screenshot)
>> > Bradley Mclain
>> >> From: "Gregor Mosheh" <gregor at hostgis.com>
>> >> Reply-To: support at hostgis.com
>> >> To: "Brad_Mclain" <bradleym06 at HOTMAIL.COM>
>> >> CC: mapserver-users at lists.umn.edu
>> Alignment
>> >> Date: Thu, 1 Feb 2007 23:02:05 -0700 (MST)
>> >>> Ok here is the sitution I have a raster image and shapefile data
>> but the
>> >>> two do not line up correctly.
>> >> Are you positive that they're both in the same projection? Or, do
>> you know
>> >> the projection for each one? I've had so many annoyances in the
>> past where
>> >> something was in "CA State Plane II" and then had to figure out
>> which of
>> >> the five CA State Plane II projections it really was. :)
>> >> If you know the projection for each, be sure to specify it in your
>> mapfile
>> >> using a PROJECTION block in your LAYER block. You can probably get
>> more
>> >> help on that once we know a bit more about the matter.
>> >> Best of luck, Brad.
>> >> -G
>> > _________________________________________________________________
>> > Join the millions of Australians using Live Search. Try live.com.au
>> http://ninemsn.com.au/share/redir/adTrack.asp?mode=click&clientID=740&referral
>> > =million&URL=http://live.com.au
> Advertisement: Meet Sexy Singles Today @ Lavalife - Click here
> http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Flavalife9%2Eninemsn%2Ecom%2Eau%2Fclickthru%2Fclickthru%2Eact%3Fid%3Dninemsn%26context%3Dan99%26locale%3Den%5FAU%26a%3D23769&_t=754951090&_r=endtext_lavalife_dec_meet&_m=EXT
