feature-id in getfeatureinfo requests
Richard Duivenvoorde
rdmailings at DUIF.NET
Mon Feb 5 10:25:27 EST 2007
Hi Bart,
Thanks for the quick response :-)
I tried that already, but in the text output, I see ALL columns of the
table (though not the 'oid' as a normal 'attribute') in the output. But
there is this line:
'Feature 17246'
Which IS the oid/feature_id....
In the gml I also receive ALL columns in the output, but NO reference to
this 17246 oid/feature_id/id...
I tried all these:
"ows_include_items" "all"
"gml_include_items" "all"
"wms_include_items" "all"
is the oid-column not an official attribute column or something like that?
Richard
Bart van den Eijnden (OSGIS) wrote:
> Hi Richard,
> you need to add
> GML_INCLUDE_ITEMS "all"
> to your LAYER's METADATA section.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Richard Duivenvoorde <rdmailings at DUIF.NET>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo requests
> Datum: 05/02/07 13:01
>> Hi All,
>> busy using getfeatureinfo from a postgresql/postgis layer.
>> Mapserver version 4.8.3 (...)
>> Postgresql-table is a point table and has a oid column (create script
>> with 'WITH OIDS').
>> I managed to get the getfeatureinfo up and running, but stumble upon the
>> missing (feature)-id in the gml output:
>> When I do an info format of 'text/plain' I'll receive something like:
>> GetFeatureInfo results:
>> Layer 'testpoints'
>> Feature 17246:
>> bla = 'zyz'
>> foo= ''
>> but when i ask for 'application/vnd.ogc.gml' as info format I receive
>> gml without the feature-id (not even as a normal 'oid' property??):
>> <?xml version="1.0" encoding="ISO-8859-1"?>
>> <msGMLOutput
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <testpoints_layer>
>> <testpoints_feature>
>> <gml:boundedBy>
>> <gml:Box srsName="EPSG:28992">
>> <gml:coordinates>67349.250981,549785.660401
>> 67349.250981,549785.660401</gml:coordinates>
>> </gml:Box>
>> </gml:boundedBy>
>> <bla>zyz</bla>
>> <foo></foo>
>> </testpoints_feature>
>> </testpoints_layer>
>> </msGMLOutput>
>> Am I missing some metadata property in my mapfile? I would expect either
>> a feature-id attribute in the testpoints_feature element, OR oid-element
>> as child of the testpoints_feature element.
>> TIA,
>> Richard
