shpree error while loading shared libraries
P Kishor punkish at EIDESIS.ORG
Mon Feb 5 14:19:53 EST 2007
My software maker friend tells me that he has the following in the Makefile --
# ESRI SDE Support. You MUST have the SDE Client libraries and include files
# on your system someplace. The actual SDE server you wish to connect to can
# be elsewhere.
SDE=      -DUSE_SDE
SDERASTER=
SDE_LIB=  -L/usr/local/arcsde/sdeexe83/lib -lsde83 -lpe83 -lsg83 -lpthread -ldl
SDE_INC=  -I/usr/local/arcsde/sdeexe83/include
All this seems to be in place. The question is, why cannot shptree
find libsde83.so?  It lives here:
/usr/local/arcsde/sdeexe83/lib/libsde93.so Where it would be expected?
On 2/5/07, P Kishor <punkish at eidesis.org> wrote:
> On 2/5/07, Howard Butler <hobu at iastate.edu> wrote:
> > It appears that they linked it against the ArcSDE libraries.  You
> > will likely have to recompile yourself or acquire the SDE SDK .so
> > files for ArcSDE 8.3.
> Yes, so they did. Yet, everything else works (well, I should correct
> that -- mapserv works fine via cgi, but the command line utils croak).
> Question -- can I build shptree all by itself (in fact, I would like
> to do that on my Macbook as well without having to build the entire
> kitchen sink).
> A related question -- it is correct to assume that indexes built on
> one computer will work on another computer? So, if I index my shape
> files on a 'doze computer and move it to Red Hat or Mac, will the
> indexes work?
> > At 12:43 PM 2/5/2007, P Kishor wrote:
> > >I was trying to use shptree that someone else had built. I got the
> > >following error.
> > >/usr/src/mapserver-4.4.2/shptree: error while loading shared
> > >libraries: libsde83.so: cannot open shared object file: No such file
> > >or directory
> > >How can I make this work? This is on Red Hat Advanced Server or some
> > >such thing.
> Puneet Kishor http://punkish.eidesis.org/
> Nelson Inst. for Env. Studies, UW-Madison http://www.nelson.wisc.edu/
> Open Source Geospatial Foundation http://www.osgeo.org/education/
> collaborate, communicate, compete
