Problem with OGR connection for XY point layer
Gaston Izaguirre
gizagui at FI.UBA.AR
Tue Feb 6 16:17:03 EST 2007
Murat,
Thank you very much for your quick answer. I've solved the problem. As a
member of the ms4w-users list suggested, it was a locale issue... The
numbers came back in the format -xx.xxxxxx -yy.yyyyyy and my local
configuration defined the period for thousands separator and the coma for
decimal seperator. So, I inverted the separators and the problem has gone.
Best regards,
Gaston.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, February 06, 2007 3:48 AM
Subject: Re: [UMN_MAPSERVER-USERS] Problem with OGR connection for XY point
layer
> Dear Gaston,
> The point which you would like to se on the map should be define as double
> field type in the table for MySql.
> May be this can be help you.
> regards...
> Murat
> On Mon, 5 Feb 2007 22:34:54 -0300, Gaston Izaguirre wrote
>> Hi all,
>> I'm using MS4W 1.5.5 on WinXP SP2 (mapserver 4.8.4, PHP 4.4.3,
>> php_mapscript_48.dll, GDAL to 1.3.2).
>> I'm trying to connect to a SQL server 2000 through an OGR Virtual
>> Format driver to obtain X,Y coordinates plus other ancillary data
>> from a View that I defined in the database. The data base is updated
>> constantly with new coordinates, so the number of rows can change,
>> actually there are about 20 points.
>> The syntax of my .OVF file is:
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="puntos">
> <SrcDataSource>ODBC:mi_usuario/mi_password at mi_DSN,mi_vista_de_la_bd</SrcDataSource>
>> <SrcLayer>mi_vista_de_la_bd</SrcLayer>
>> <!-- <FID>Poul_id</FID> -->
>> <GeometryType>wkbPoint</GeometryType>
>> <LayerSRS>WGS84</LayerSRS>
>> <!-- <LayerSRS>EPSG:4326</LayerSRS> -->
>> <GeometryField encoding="PointFromColumns" x="Poul_longitud"
>> y="Poul_latitud"/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> I´ve tested with OGRINFO and the result is something like the following:
>> Layer name: puntos
>> OGRFeature(puntos):0
>> Vehi_textid (String) = 276 33
>> Poul_id (Integer) = 73
>> Poul_vehi_id (Integer) = 9
>> Poul_latitud (Real) = -34
>> Poul_longitud (Real) = -58
>> Poul_velocidad (Real) = 0
>> Poul_sentido (String) = 0
>> Poul_posi_fecha (String) = 31/01/2007 12:18:46
>> POINT (-58 -34 0)
>> OGRFeature(puntos):1
>> Vehi_textid (String) = 276 58
>> Poul_id (Integer) = 63
>> Poul_posi_fecha (String) = 05/02/2007 17:44:02
>> POINT (-58 -34 0)
>> OGRFeature(puntos):19
>> Vehi_textid (String) = 276 59
>> Poul_id (Integer) = 64
>> Poul_velocidad (Real) = 12
>> Poul_sentido (String) = 170
>> Poul_posi_fecha (String) = 05/02/2007 22:09:35
>> POINT (-58 -34 0)
>> As you can see, the connection retrieves the 20 points, but there is
>> a problem with the X/Y (lat/lon) values: they are rounded to the
>> integer part, in spite of being defined as real in the database. For
>> example, for the last point (#19) I get: xcoord = -58 ycoord = -34
>> when the actual value is: x = -58.904272 y = -34.447837
>> As a result of this, when I test the mapfile with SHP2IMG all 20
>> points are in the same place (all with the same coordinate values;
>> e.g. x,y = -58,-34)
>> I am making some mistake?
>> My syntax is correct?
>> Is there someone to give me a hand on this problem?
>> Thanks in advance,
>> Gaston.
>> This message has been scanned for viruses and
>> dangerous content by MailScanner, and is
>> believed to be clean.
> Murat Beyhan
> Jeofizik Yük. Müh.
> Afet İşleri Genel Müdürlüğü
> Deprem Araştırma Dairesi
> Eskişehir Yolu 12. Km. Lodumlu/Ankara
> Tel:+90 (312) 2872680-1550
