Problem in web template {Scanned}
Siki Zoltan siki at AGT.BME.HU
Wed Feb 7 06:08:35 EST 2007
Try to add .exe to the action parameter of the form.
   <form method =POST action = "/cgi-bin/mapserv.exe">
bye
Zoltan
On Tue, 6 Feb 2007, Saif wrote:
> Hi,
> I am a newbie in mapserver and have a problem in using web template
> <html>
>  <head> <title> GIS Application </title> </head>
>  <body>
>   <form method =POST action = "/cgi-bin/mapserv">
> 	<input type = "submit" value ="Click to Intialize">
> 	<input type = "hidden" name ="map" value
> = "/ms4w/apps/MyApplic/htdocs/WSLT.map">
>   	<input type = "hidden" name ="mapext" value = "644939.974768
> 5571028.735107 777118.073090 5711137.519287">
> 	<input type = "hidden" name ="zoomsize" size =2 value =2>
> <input type="hidden" name="program" value="/cgi-bin/mapserv">
> <input type="hidden" name="map_web_imageurl" value="/tmp/">
>        </form>
>  </body>
> </html>
> When I run the web page and tried "Click to Intialize", it showed me
> "No page can not be displayed"
> and in address bar I got this line
> C:\cgi-bin\mapserv
> When I tried mapserv.exe instead mapserv in action = "/cgi-bin/mapserv.exe",
> it asked me to save or run the mapserv.exe. I have checked ms4w folders. I
> have read and write permissons. Environemnt variables are ok. When I tried to
> check mapserv at command prompt, it gave me
> The script can only be used to decode from results and should be initiated as
> a CGI process via a httpd server.
> I tried mapserv -v as well and it showed me mapserv version 4.10.0
> OUTPUT=GIF OUTPUT=GIF ....................................
> in map file I have also described web template
> # web Object
> WEB
> 	TEMPLATE	"/ms4w/apps/MyApplic/templates/"
> 	IMAGEPATH	"/ms4w/apps/MyApplic/images/"
> 	IMAGEURL	"/tmp/"
> 	LOG		"/tmp/mapserver.log"
> END
> I am wondering if anybody can help me with this problem.
> Thanks
