Mapscript compile error
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Feb 7 11:33:00 EST 2007
As Frank said you are running on the edge so it is possible that there
will be issues.
The error is critical only if you need to use GDAL. To check that the
linker can resolve all symbols run:
ldd -r libmapscript.so
or
ldd -r mapserver
Regards,
Umberto
On 2/7/07, Hans Wapenaar <hans.wapenaar at gis-innovations.nl> wrote:
> Yes,
> I had to install g++
> (on Debian Linux: apt-get install g++)
> and that worked!
> After compiling mapserver I also could make the mapscript/java stuff.
> libmapscript.so and mapscript.jar are available now. So next step is trying to
> get my servlets running with Tomcat. (on a windows system I got them
> already running).
> In the proces of compiling mapserver I still got an error. Is that critical for
> mapserver or has it only to do with shp2img?
> /opt/FWTools-1.2.0/lib/libgdal.so: undefined reference to
> `CNCSError::CNCSError(CNCSError const&)'
> `CNCSJPCIOStream::WriteIEEE8(double)'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
