Problem with queryByAttributes
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Feb 8 12:21:26 EST 2007
I had seen a similar problem recently with mapserver 4.10.0 but It
worked ok with mapserver cvs. I could not loacate quickly what the fix
was. If you have the ability to try mapserver from cvs, It could solve
your problems. Hope it helps.
Later,
Dirk Jesko wrote:
> Hello,
> I would like to query a layer which gets its data from PostGIS. Which
> syntax has to be used for the qstring argument of the queryByAttributes
> function? I tried the usual syntax of a WHERE clause, but it failed.
> Example:
> queryByAttribures("gid", "gid = 16", MS_MULTIPLE) and
> queryByAttribures("gid", "gid = 16 OR gid = 17", MS_MULTIPLE) work.
> However, the following calls do not work
> queryByAttribures("gid", "gid = '16'", MS_MULTIPLE)
> queryByAttribures("gid", "gid IN (16, 17)", MS_MULTIPLE)
> In such a case postgres reports a syntax error, because the WHERE clause
> is incomplete: WHERE (gid = ) resp. WHERE (gid IN ), i.e. the values are
> missing.
> Do I have to specify the expression differently or is this a bug?
> Thanks,
> Dirk
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
