Problem with connecting to MySQL with OVF-file
Karl Suiter
karl.suiter at GMAIL.COM
Thu Feb 8 19:08:19 EST 2007
Chris Beaart <beaart <at> XS4ALL.NL> writes:
> Hello,
> I’m running Mapserver and pMapper on a Linux-Debian system and I
> have installed MySQL, added a database called dop and a table called
> waarnemingen.
> deleted stuff ....
> FAILURE:
> Unable to open datasource
> `/var/www/data/maps/waarnemingen.ovf' with the following drivers.
> -> ESRI Shapefile
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> MapInfo File
> -> DGN
> -> VRT
> -> AVCBin
> -> REC
> -> Memory
> -> CSV
> -> GML
> -> ODBC
> -> PostgreSQL
> Can somebody please help to connect to
> MySQL database. What could be wrong?
> Thanks.
> Chris Beaart
Chris,
Your OGR output error indicates that your Mapserver binary has not been
compiled with MySQL connectivity enabled. You can also run "mapserv -v" and the
output should include the "INPUT=MYSQL" statement.
On Linux, you'll need to run the configure command with "--with-mysql= ..." to
set this option before running make. I needed to have the mysql client and
development libraries installed before I could get the connection to work. You
may not need to do this.
FYI - my configuration is Fedora Core 5, Mapserver 4.10, MySQL 5.01.
Cheers,
Karl
