Problem with queryByAttributes
Dirk Jesko ml.dje at GEOCONTENT.DE
Fri Feb 9 03:22:28 EST 2007
Hi Armin,
thanks for the info. I added the quotes in the PHP code. This should
work until a new stable version is published.
Dirk
Armin Burger wrote:
> Dirk
> I was wondering that your first 2 queries worked. There seems to be a
> bug in Mapserver 4.10 and filters and attribute queries on PostGIS
> that requires to submit literal double quotes, like
>  queryByAttribures("gid", "\"gid = '16'\"", MS_MULTIPLE)
> otherwise the WHERE clause gets truncated. I read that it is fixed in
> CVS, but so far no stable release with these bug fixes is available.
> armin
> Dirk Jesko wrote:
>> Hello,
>> I would like to query a layer which gets its data from PostGIS. Which
>> syntax has to be used for the qstring argument of the
>> queryByAttributes function? I tried the usual syntax of a WHERE
>> clause, but it failed. Example:
>> queryByAttribures("gid", "gid = 16", MS_MULTIPLE) and
>> queryByAttribures("gid", "gid = 16 OR gid = 17", MS_MULTIPLE) work.
>> However, the following calls do not work
>> queryByAttribures("gid", "gid = '16'", MS_MULTIPLE)
>> queryByAttribures("gid", "gid IN (16, 17)", MS_MULTIPLE)
>> In such a case postgres reports a syntax error, because the WHERE
>> clause is incomplete: WHERE (gid = ) resp. WHERE (gid IN ), i.e. the
>> values are missing.
>> Do I have to specify the expression differently or is this a bug?
>> Thanks,
>> Dirk
