Problem activating SDE in MS4W v2.2.2
Javier Sánchez
jsanchezfr at SUPERCABLE.ES
Fri Feb 9 13:04:14 EST 2007
Javier Sánchez wrote:
> I've downloaded the las version of MS4W (2.2.2).
> Installed, and tried to activate SDE support using:
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde-9-1
> Tried "mapserv -v", and "INPUT=SDE" was printed out.
> Tried "ogrinfo SDE:..." and data obtained (this assure that the server is
> accessible).
> But now MapServer is down. None of the Maps (with and without SDE) are
> working.
> If I copy original "libmap.dll" in "/ms2w/Apacge/cgi-bin", the server
> works fine again (but not SDE, of course).
> What's the problem?
> The server shows this message:
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
> <html><head>
> <title>500 Internal Server Error</title>
> </head><body>
> <h1>Internal Server Error</h1>
> <p>The server encountered an internal error or
> misconfiguration and was unable to complete
> your request.</p>
> <p>Please contact the server administrator,
> admin at local.domain and inform them of the time the error occurred,
> and anything you might have done that may have
> caused the error.</p>
> <p>More information about this error may be available
> in the server error log.</p>
> </body></html>
> In Apache log error:
> [Wed Feb 07 12:26:10 2007] [error] [client 127.0.0.1] Premature end of
> script headers: mapserv_sde.exe
> Please, help!!!!!
> PD: Sorry for my *bad* english...
> PPD: I've changed to the previous version of MS4W, and SDE works fine.
> There is something wrong with the new MS4W version.
The mistery is: when I tried to activate SDE in another MS4W copy (version
2.2, not the last 2.2.2), the problem exist!!!!
I've only got one MS4W working with SDE... I've done the same to get the SDE
working... :-?
View this message in context: http://www.nabble.com/Problem-activating-SDE-in-MS4W-v2.2.2-tf3186353.html#a8890611
Sent from the Mapserver - User mailing list archive at Nabble.com.
