Problem activating SDE in MS4W v2.2.2
Javier Sánchez jsanchezfr at SUPERCABLE.ES
Sat Feb 10 06:28:44 EST 2007
I think that i've solved the problem: Reboot the machine!!!!!!!
After install the SDE SDK, you have to reboot (the installer didn't informed
me about this trouble).
Bye!
Javier.
Javier Sánchez wrote:
> I've downloaded the las version of MS4W (2.2.2).
> Installed, and tried to activate SDE support using:
> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde-9-1
> Tried "mapserv -v", and "INPUT=SDE" was printed out.
> Tried "ogrinfo SDE:..." and data obtained (this assure that the server is
> accessible).
> But now MapServer is down. None of the Maps (with and without SDE) are
> working.
> If I copy original "libmap.dll" in "/ms2w/Apacge/cgi-bin", the server
> works fine again (but not SDE, of course).
> What's the problem?
> The server shows this message:
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
> <html><head>
> <title>500 Internal Server Error</title>
> </head><body>
> <h1>Internal Server Error</h1>
> <p>The server encountered an internal error or
> misconfiguration and was unable to complete
> your request.</p>
> <p>Please contact the server administrator,
>  admin at local.domain and inform them of the time the error occurred,
> and anything you might have done that may have
> caused the error.</p>
> <p>More information about this error may be available
> in the server error log.</p>
> </body></html>
> In Apache log error:
> [Wed Feb 07 12:26:10 2007] [error] [client 127.0.0.1] Premature end of
> script headers: mapserv_sde.exe
> Please, help!!!!!
> PD: Sorry for my *bad* english...
> PPD: I've changed to the previous version of MS4W, and SDE works fine.
> There is something wrong with the new MS4W version.
View this message in context: http://www.nabble.com/Problem-activating-SDE-in-MS4W-v2.2.2-tf3186353.html#a8899836
Sent from the Mapserver - User mailing list archive at Nabble.com.
