Custom Projection
Abe Gillespie
abe.gillespie at GMAIL.COM
Mon Feb 12 15:34:57 EST 2007
Hello all,
Forgive my ignorance on the subject - is there a way to define a
custom projection such that it simply applies a rotation to the map?
For instance, instead of the map being oriented with the top as north,
I need to orient it in a "you are here" fashion. I want to put the
entrance of a building at due south.
First, in general, can this even be done? What I mean to say is are
projections even used in this fashion? Second, if it can be done, how
does one go about defining a custom projection? Can you fire up
ArcGIS and use the GUI? Are there command line tools?
Thanks for any help.
-Abe
