ArcSDE Version Error
Howard Butler hobu at IASTATE.EDU
Wed Feb 14 10:22:03 EST 2007
MapServer is connecting to SDE just fine, but I think you have your
DATA block specified incorrectly.  SE_version_get_info is a function
queries SDE get the specific version of the layer you wish to connect
to.  If you are using SDE in multiple-editor scenario, this is useful
for showing where the states of specific version of the layers are.
What do your CONNECTION and LAYER blocks look like (minus sensitive
info, of course)?
Howard
On Feb 14, 2007, at 8:54 AM, Fawcett, David wrote:
> I am trying to get a MapServer ArcSDE connection working.  When I hit
> mapserv, I get the follwing errors: =20
> msDrawMap(): Image handling error. Failed to draw layer named
> 'testsde'.
> msSDELayerOpen(): SDE error. SE_version_get_info(): Version not found.
> (-126)=20
> I didn't do the compile myself.  Since I don't see any examples where
> the version is set in the map file, I am guessing that this error is
> showing up because the version was not properly set with the compile
> option '--with-sde-version=3D90'. =20
> Can anyone confirm (or refute) this? =20
> Thanks,=20
> David.
