Problems with ArcSDE & MapServer (Premature end of script headers)
Shim, Stephen Stephen.Shim at CA.COM
Fri Feb 16 01:45:43 EST 2007
I have a problem with MapServer connecting to our ArcSDE server.
The error logs show a "Premature end of script headers" error.
I'm using MapServer 4.8.4 and have tried 4.10.0, which also returns the same error.
Previously, I used MapServer 4.6.2 and have had no problems connecting to ArcSDE.
In all three cases (MapServer 4.8.4, 4.10.0 and 4.6.2), I used the same mapfile.
The different versions of MapServer were compiled with ArcSDE support
using the maptools.org "fgs" toolkit on Red Hat Linux servers.
If you have used MapServer 4.8.4 or 4.10.0 connecting to ArcSDE on Red Hat Linux successfully,
I'd like to hear from you.
ENVIRONMENT
We have the MapServer running on a Linux box and ArcSDE running on a Windows box.
MapServer Server:
* MapServer 4.8.4
* Red Hat ES4
ArcSDE Server:
* Windows 2003 Server.
* ArcSDE 9.1 (Release: 91003) [BugFix: 0]
* Oracle9i  Build 1269
ERROR LOGS:
I turned on error logging in MapServer and here are the results:
Debug Information from MapServer 4.8.4
[Thu Feb 15 15:31:57 2007].578336 msWMSLoadGetMapParams(): enabling non-square pixels.
[Thu Feb 15 15:31:57 2007].590997 msDrawMap(): kicking into non-square pixel preserving mode.
[Thu Feb 15 15:31:57 2007].591072 msSDELayerOpen(): Layer CALM_REGIONS opened from scratch.
[Thu Feb 15 15:31:58 2007].119776 msConnPoolRegister(CALM_REGIONS,sliptest,port:5151,slip,sde,aslkzxmn,0x93d5ab8)
[Thu Feb 15 15:31:58 2007].119834 msSDELayerOpen(): Layer CALM_REGIONS specified version SDE.DEFAULT.
[Thu Feb 15 15:31:58 2007].121464 msSDEGetLayerInfo(): Looking for layer by SDE.CALM_REGIONS, SHAPE, sliptest,port:5151,slip,sde,aslkzxmn
[Thu Feb 15 15:31:58 2007].121516 msSDEGetLayerInfo(): No cached layerid found.
[Thu Feb 15 15:31:58 2007].123143 msSDELCacheAdd(): Caching id for SDE.CALM_REGIONS, SHAPE, sliptest,port:5151,slip,sde,aslkzxmn
[Thu Feb 15 15:31:58 2007].124391 msSDELayerGetRowIDColumn(): Table was not registered, returning SE_ROW_ID.
[Thu Feb 15 15:31:58 2007].124620 msSDELayerGetRowIDColumn(): Table was not registered, returning SE_ROW_ID.
[Thu Feb 15 15:31:58 2007] [error] [client 172.20.249.52] Premature end of script headers: /MapServer410/www/cgi-bin/mapserv
On MapServer 4.6.2, which succeeded in returning an image, I also obtained debugging information to compare:
Debug Information from MapServer 4.6.2
[Fri Feb 16 13:13:41 2007].3009   msWMSLoadGetMapParams(): enabling non-square pixels.
[Fri Feb 16 13:13:41 2007].12309  msDrawMap(): kicking into non-square pixel preserving mode.
[Fri Feb 16 13:13:41 2007].12389  msSDELayerOpen(): Layer CALM_REGIONS opened from scratch.
[Fri Feb 16 13:13:41 2007].571953 msConnPoolRegister(CALM_REGIONS,sliptest,port:5151,slip,sde,aslkzxmn,0x82d1000)
[Fri Feb 16 13:13:41 2007].572006 msSDELayerOpen(): Layer CALM_REGIONS specified version SDE.DEFAULT.
[Fri Feb 16 13:13:41 2007].586505 msSDEGetLayerInfo(): Looking for layer by SDE.CALM_REGIONS, SHAPE, sliptest,port:5151,slip,sde,aslkzxmn
[Fri Feb 16 13:13:41 2007].586526 msSDEGetLayerInfo(): No cached layerid found.
[Fri Feb 16 13:13:41 2007].593036 msSDELCacheAdd(): Caching id for SDE.CALM_REGIONS, SHAPE, sliptest,port:5151,slip,sde,aslkzxmn
[Fri Feb 16 13:13:41 2007].594426 msSDELayerGetRowIDColumn(): Table was not registered, returning SE_ROW_ID.
[Fri Feb 16 13:13:41 2007].594652 msSDELayerGetRowIDColumn(): Table was not registered, returning SE_ROW_ID.
[Fri Feb 16 13:13:41 2007].729126 msDrawMap(): Layer 1 (CALM_REGIONS), 0.717s
[Fri Feb 16 13:13:41 2007].729202 msDrawMap(): Drawing Label Cache, 0.000s
[Fri Feb 16 13:13:41 2007].729233 msDrawMap() total time: 0.717s
[Fri Feb 16 13:13:41 2007].732874 msPOSTGISLayerClose datastatement: the_geom from cadastre
[Fri Feb 16 13:13:41 2007].732905 msPOSTGISLayerClose -- layerinfo is  NULL
[Fri Feb 16 13:13:41 2007].732923 msSDELayerClose(): Closing layer CALM_REGIONS.
[Fri Feb 16 13:13:41 2007].732962 msConnPoolRelease(CALM_REGIONS,sliptest,port:5151,slip,sde,aslkzxmn,0x82d1000)
[Fri Feb 16 13:13:41 2007].732983 msConnPoolClose(sliptest,port:5151,slip,sde,aslkzxmn,0x82d1000)
Here is the mapfile LAYER definition that we tried connecting.
        LAYER
         NAME "CALM_REGIONS"
         CONNECTION "sliptest,port:5151,slip,sde,aslkzxmn"
         CONNECTIONTYPE SDE
         DATA "SDE.CALM_REGIONS,SHAPE,SDE.DEFAULT"
         DEBUG ON
         STATUS ON
         GROUP "CALM"
         DUMP true #required for wfs
         TYPE polygon
         TEMPLATE 'demo.html'
         METADATA
          "wms_title"           "CALM - CALM Regions"
          "wms_srs"             "EPSG:4283 EPSG:4326 EPSG:28349 EPSG:28350 EPSG:28351 EPSG:28352"
          "wms_extent"          "112.866 -35.2419 129.001 -13.5101"
          "wms_group_title"     "CALM"
          "gml_include_items"   "all"  ## optional (serves all attributes for layer)
         END #METADATA
         PROJECTION
          "init=epsg:4283"
         END
         CLASS
          NAME 'CALM_Regions'
          STYLE
           SYMBOL "line-vertical"
           COLOR 0 0 255
           OUTLINECOLOR 0 0 0
           SIZE 5
          END #STYLE
          STYLE
           SYMBOL "line-horizontal"
           COLOR 0 0 255
           OUTLINECOLOR 0 0 0
           SIZE 5
          END #STYLE
         END #CLASS
       END #LAYER
I would greatly appreciate it if anyone can offer any help in this matter.
Sincerely,
Stephen Shim
SLIP Team
Email: Stephen.Shim at ca.com <mailto:Stephen.Shim at ca.com>
CA Phone: 9488 8193
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070216/14cd200c/attachment.html
