WMS GetFeatureInfo with GML output without WFS
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Fri Feb 16 09:26:29 EST 2007
I don't know of a way to do this.
You can however limit the number of features (server-side) that your WFS
will return, by using wfs_maxfeatures LAYER METADATA. You can try to set it
to 1 (or see if setting it to 0 works).
Would that be an option for you?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: François Prunayre <fx.prunayre at OIEAU.FR>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] WMS GetFeatureInfo with GML output without
WFS
Datum: 16/02/07 12:00
> Hi list, what's the
> configuration to be able to do a WMS GetFeatureInfo with output in GML
without
> giving access to the layer in WFS ?
> If I follow the how
> to :
> "For GetFeatureInfo requests of GML you must set
> the layer to DUMP TRUE in the mapfile. As of MapServer 4.6 you must also
set the gml_* metadata for the layer attributes to be served (see the Layer
> Object metadata in the Reference Section later in this document)."
> but then I'll be
> able to do the GetFeatureInfo but also I'll activate the WFS.
> Any ideas ? Maybe we
> can't do that ?
> Thanks for your
> help.
> Francois
> This message has been scanned by the Trend Micro IGSA and found to be free
of known security risks.
