postgis and mapserver again
Pietro Giannini pgiannini at BYTEWISE.IT
Fri Feb 16 10:03:27 EST 2007
Maybe you don't set the EXTENT or the SIZE in the .map file.
Take a
look here: http://mapserver.gis.umn.edu/docs/reference/mapfile/mapObj
bye
Pietro Giannini
Bytewise srl - Area
GIS
41°50'38.58"N 12°29'13.39"E
On
Ven, 16 Febbraio 2007 2:18 pm, Agustina Buccella wrote:
> Thanks
for the answers.... I thought that the problem was the TYPE in the
> mapfile but the problem was another one... when I try to see data
using
> the URL:
http://localhost/cgi-bin/mapserv?map=/usr/local/apache2/htdocs/mapserver/ejemplo_postgis3.map&mode=map
>  I receive the following errors:
msDrawMap(): Image handling error. Unable to initialize image.
msPrepareImage(): General error message. Image dimensions not
specified.
>   msCalculateScale(): General error message. Invalid
image extent,
> minx=-1.000000, miny=-1.000000, maxx=-1.000000,
maxy=-1.000000.
>   mapserv(): Web application error. No way to
generate map extent.
>  My .map file contains the
following:
>  LAYER
>    NAME pg_test
   TYPE POINT
>    STATUS DEFAULT
>    CONNECTIONTYPE
POSTGIS
>     CONNECTION "host=localhost port=5432
dbname=miprimergis password=****
> user=*****"
DATA "the_geom FROM cities"
>  END
>  END
>  and my .sql to load data in the postgis database is:
>  BEGIN;
>  CREATE TABLE "cities" (gid
serial PRIMARY KEY,
>  "city_name" varchar(40),
>  "gmi_admin" varchar(7),
"admin_name" varchar(42),
>  "fips_cntry"
varchar(2),
>  "cntry_name" varchar(40),
"status" varchar(50),
>  "pop_rank" int2,
>  "pop_class" varchar(22),
>  "port_id"
int2);
>  SELECT
AddGeometryColumn('','cities','the_geom','-1','POINT',2);
INSERT INTO "cities"
("city_name","gmi_admin","admin_name","fips_cntry","cntry_n
ame","status","pop_rank","pop_class","port_id",the_geom)
VALUES
> ('Drammen','NOR-
BSK','Buskerud','NO','Norway','Provincial capital','6','50,000 to
> 100,000','2378
0','01010000000000006066662440000000A099D94D40');
>  INSERT INTO
"cities"
VALUES
> ('Trinidad','BOL
>  -EBE','El
Beni','BL','Bolivia','Provincial capital','6','50,000 to
100,000','0',
>  '0101000000000000C0CA3950C00000008097AE2DC0');
>  END;
>  I read the same error in the list but
it was not the answer....
>  Thanks!
Agustina
>  Preguntá.
Respondé. Descubrí.
>  Todo lo que querías
saber, y lo que ni imaginabas,
>  está en Yahoo! Respuestas
(Beta).
>  Probalo ya!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070216/5d71b8f7/attachment.html
