[postgis-users] Howto: PostGIS on Vista / IIS7
Ken Lord
kenlord at GMAIL.COM
Sun Feb 18 19:02:21 EST 2007
HI Bruce,
Certainly, please do so.
Thanks,
Ken
On 2/18/07, Bruce Rindahl <rindahl at lrcwe.com> wrote:
> Ken
> Thanks for a great how-to!
> Can we add this to the windows installer how-to?
> Bruce Rindahl
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ken Lord
> Sent: Sunday, February 18, 2007 2:45 PM
> To: postgis-users at postgis.refractions.net; mapserver-users at lists.umn.edu
> Subject: [postgis-users] Howto: PostGIS on Vista / IIS7
> Hi Lists,
> I recently upgraded to Windows Vista / IIS7, and found very little
> help on the internet regarding installing PostgreSQL / PostGIS, most
> 'help' consists of useless trolls and flame wars. Seems the open
> source community would rather fight each other than try to play nice
> with the new Microsoft OS platform.
> The standard win32 installer of PostgreSQL fails on its own. There are
> a some tricks needed to get through the new security measures in
> Vista, but it can be done, and in the end it works fine. Here's how:
> 1. Turn off the Windows Vista User Account Contral (UAC). This is done
> from Users in the Control Panel.
> 2. Enable the Vista 'Administrator' user account. By default it is disabled.
> - In the Start Menu, right click on Computer, select Manage
> - In System Tools / Local Users and Groups / Users, open the
> properties of the Administrator account and enable it. You will have
> to assign a new password to the account. Installation will not work
> from a regular account with administrator rights, it must be this
> master Administrator account.
> 3. Create a new standard limited user account called postgres. Give it
> a password. The PostgreSQL installer can not create this account in
> Vista so do it ahead of time yourself.
> 4. Login to the new Administrator account.
> 5. Install PostgreSQL from the windows msi installer file. Remember to
> not install PostGIS at this point, you'll want the more upto date
> version than wha tthe installer has.
> - It will ask for the postgres username and password you created in step 3.
> - Install as a Service
> - DO NOT select to have the installer initialize a new database. It
> will not work. postgres.exe protects you by not running when it has
> administrator rights, if you try to have the installer initialize a
> new database you will get an 'initdb failed' error message and the
> installation will rollback. If you dig deeper it will tell you that
> initdb can not find the postgres application even though it is present
> in the bin directory. It is there, it just won't run.
> 6. When the installer has finished successfully, logout of windows.
> Log back in as the postgres user.
> 7. Open a command prompt, this is found in Accessories in the start
> menue / All Programs.
> 8. Initialize a postgresql database.
> - change to the C:\Program Files\PostgreSQL\8.2\bin directory
> - run a command something like:
> initdb -D "C:\Program FIles\PostgreSQL\8.2\data" -U postgres -E UTF8
> 9. You should now have a working installation of PostgreSQL. Install
> PostGIS using the appropriate installer from www.refractions.net.
> Remember to get the installer that is made for your version of
> PostgreSQL.
> 10. Disable the Administrator account and turn UAC back on.
> 11. Profit!!
> >From here I had no problems loading data into PostGIS in the usual
> ways, my MapServer site is working normally, no problems using it's
> PostGIS layers ... although IE7 doesn't seem to like the Rosa applet
> much, but that's another story.
> Cheers,
> Ken Lord
> Vancouver BC
> postgis-users mailing list
