loading data through a view
Fran çois Bruneau
francois.bruneau at WESTIMAGES.COM
Mon Feb 19 04:31:20 EST 2007
Hi everyone,
I am currently running some performance tests on MapServer, using an Oracle Spatial data set, and there are results that I have some trouble interpreting.
The debug mode outputs the precise fetch+render time of each layer. Here are the results I get:
To load 50000 line objects through a "BENCH_LINE_50K" view defined as follows:
SELECT * FROM MY_LINES WHERE ROWNUM<=50000
it takes 178.937s.
To load the same objects but using a FILTER statement directly applied to the MY_LINES table, it takes only 2.938s !
Here is my layer definition:
LAYER
NAME "BENCH_LINE_50K"
CONNECTION "safgis/safgis at lydec"
CONNECTIONTYPE oraclespatial
DATA "GEOMETRY FROM BENCH_LINE_50K"
#DATA "GEOMETRY FROM MY_LINES"
#FILTER "ROWNUM<=50000"
TYPE LINE
DEBUG ON
CLASS
STYLE
COLOR 192 192 192
END
END
END
Does anyone have an idea on what could explain this huge difference ?
Thanks in advance,
François.
