reprojection within map file does not seem to slow down
performance within mapserver
Frank Warmerdam
warmerdam at POBOX.COM
Tue Feb 20 12:39:57 EST 2007
John Mitchell wrote:
> Hi,
> I have noticed that reprojection within a map file does not seem to slow
> down performance within mapserver. The mapserver documentation states
> that if you have a different projection within the root of the map file
> and a layer then it will take 2-4 times longer to reproject, but I have
> not noticed any decrease in performance.
> Has anyone else had a similar result?
John,
Reprojection is not really terribly expensive, and whether doing it will
slow things down noticably or not depends a lot on circumstances. For instance
reprojecting a layer with a hundred label points will not take long. The
time to draw a label for each point will massively dwarf the time reproject
100 points. But reprojecting a complex line layer with 100000 vertices
and a simple rendering style may take noticably longer.
I think the documentation comment is somewhat misleading, but in general
havig reproject on the fly will make things slower - anywhere from
imperceptibly slower to significantly slower.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
