WMS and getFeatureInfo problem
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Wed Feb 21 01:28:26 EST 2007
Thanks guys... query_layers instead of querylayers... I knew it would
be something stupid...
And then text/plain... ok. Thanks for that.
Just a question for clarification: At the beginning I thought the
getfeatureinfo would only show the results of its search. Then I saw
that one had to specify as well the layers. So I thought, cool, the
getfeatureinfo draws then first the map and then shows the results.
Not bad! But now I see that it indeed really only displays a couple
of lines. What sense does it make to indicate the layers command?
Stef
On Feb 20, 2007, at 4:00 PM, Bart van den Eijnden (OSGIS) wrote:
> Hi,
> first of all, querylayers should be query_layers.
> text/html is not supported by default, I believe you need to do some
> templating for that. Check the following document and search for
> text/html:
> http://mapserver.gis.umn.edu/docs/howto/wms_server
> text/plain works using this request:
> http://gridca.grid.unep.ch/cgi-bin/mapserv?map=/www/geodataportal/
> htdocs/mod_map/
> geo_wms.map&service=wms&version=1.1.1&request=getfeatureinfo&layers=gd
> p_capita,int_boundary_lines,continent_outlines&query_layers=gdp_capita
> &x=10&y=50&info_format=text/plain&bbox=-180,-90,180,90
> Hope this helps.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] WMS and getFeatureInfo problem
> Datum: 20/02/07 12:57
>> Hi there,gush, the last hours I spent with searching my way
>> through pdfs,
> email archives and how-tos... But somehow in vain....Why does my
> getfeatureinfo not work? Probably just a tiny thing - as usual. But
> it's
> getting somewhat frustrating.Thanks for any
> hints!StefGetFeatureInfo:http://gridca.grid.unep.ch/cgi-bin/mapserv?
> map=/www/geodataportal/htdocs/mod_map/
> fo&layers=gdp_capita,int_boundary_lines,continent_outlines&que
> rylayers=gdp_capita&x=10&y=50&info_format=text/
> html&bbox=-180,-90,180,90
> GetMap:http://gridca..grid.unep.ch/cgi-bin/mapserv?map=/www/
> geo_wms.map&service=wms&version=1.1.1&request=getmap&l
> ayers=gdp_capita,int_boundary_lines,continent_outlinesGetCapabilities:
> htdocs/mod_map/
> geo_wms.map&service=wms&version=1.1.1&request=getcapabilit
> ies #
> Map definition --------------------- NAME geo_wms.map STATUS ON
> SIZE 600
> 300 EXTENT -180 -90 180 90 UNITS DD IMAGECOLOR 255 255 255
> SHAPEPATH 'xxx'
> FONTSET 'xxx' SYMBOLSET 'xxx' # End Map definition
> --------------------- # Projection definition
> --------------------- PROJECTION 'init=epsg:4326' END # End Projection
> definition --------------------- # Web definition
> --------------------- WEB IMAGEPATH 'xx' IMAGEURL 'xx' METADATA
> 'wms_title' 'GEO Data Portal WMS Server'
> 'wms_onlineresource' 'http://geodata.grid.unep.ch' 'wms_srs'
> 'EPSG:4326' "wms_getfeatureinfo"
> "http://gridca.grid.unep.ch/cgi-bin/mapserv?map=/www/geodataportal/
> htdocs/mod_map/geo_wms.map&"
> "wms_featureinfoformat" "text/plain" END END #
> End Web
> definition --------------------- # Layers definition
> --------------------- LAYER NAME gdp_capita STATUS
> OFF
> CONNECTIONTYPE postgis CONNECTION 'user=xx password=xx
> dbname=xx'
> TYPE POLYGON DATA 'xxx' TEMPLATE 'dummy'
> DUMP TRUE CLASSITEM 'y_2004' CLASS NAME ''
> EXPRESSION ([y_2004]=-10001) TEMPLATE 'empty
> space' END
> # CLASS CLASS NAME 'Units: Constant 2000 US$ per
> Person'
> EXPRESSION ([y_2004]=-110003) TEMPLATE 'units
> as title
> in legend' END # CLASS CLASS NAME
> 'no data'
> EXPRESSION ([y_2004]=-9999) COLOR 230 230 230
> TEMPLATE 'dummy' END # CLASS CLASS NAME
> '88 to
> 9634' EXPRESSION ([y_2004]<=9634) COLOR
> 255 255 178
> TEMPLATE 'dummy' LABEL FONT arial
> TYPE truetype ANTIALIAS
> false SIZE 8
> COLOR 0 0 0 POSITION AUTO
> PARTIALS FALSE FORCE true OFFSET 0 5
> #OUTLINECOLOR 0 0 0 END END # CLASS
> CLASS
> NAME '9634 to 19180' EXPRESSION ([y_2004]
> <=19180)
> COLOR 254 204 92 TEMPLATE 'dummy' LABEL
> FONT arial TYPE truetype
> ANTIALIAS false
> SIZE 8 COLOR 0 0 0
> POSITION
> AUTO PARTIALS FALSE FORCE true
> OFFSET 0 5 #OUTLINECOLOR 0 0 0 END
> END #
> CLASS CLASS NAME '19180 to 28725'
> EXPRESSION
> ([y_2004]<=28725) COLOR 253 141 60
> TEMPLATE 'dummy'
> LABEL FONT arial TYPE
> truetype
> ANTIALIAS false SIZE 8
> COLOR 0 0 0
> POSITION AUTO PARTIALS FALSE
> FORCE true OFFSET 0 5 #OUTLINECOLOR 0
> 0 0
> END END # CLASS CLASS NAME '28725
> to 38271'
> EXPRESSION ([y_2004]<=38271) COLOR 240 59 32
> TYPE truetype ANTIALIAS false SIZE 8
> PARTIALS
> #OUTLINECOLOR 0 0 0 END END # CLASS CLASS
> NAME '38271 to 47817' EXPRESSION ([y_2004]>38271)
> COLOR 189 0 38 TEMPLATE 'dummy' LABEL
> FONT arial TYPE truetype ANTIALIAS false
> SIZE 8 COLOR 0 0 0 POSITION
> AUTO
> OFFSET 0 5
> METADATA 'wms_title' 'Gross Domestic Product - per
> Capita'
> END # METADATA PROJECTION 'init=epsg:
> 4326' END
> END # LAYER ... other layers ....END # Map File
