queryByAttributes - speed
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Tue Feb 27 06:39:29 EST 2007
I don't believe the Mapinfo attribute indexes are used by Mapserver/OGR.
This is not implemented.
So if you need performance, store your data in e.g. PostGIS instead if
possible.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Jeppe Lund Andersen <JXA at COWI.DK>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] queryByAttributes - speed
Datum: 27/02/07 09:34
> Hello all
> Iam running php mapscript on a windows 2003 server and when Iam using
> queryByAttributes, but it take some time to perform the search.
> It takes between 7-8 sek for this linie
> $Qry = @$Layer-&gt;queryByAttributes($ID_navn, '(' . $Search_Str .')',
> $ResultType);
> The file iam using is a mapinfo file which has cadastral information.
> there are 156612 records in the file and the coln iam searching in has
> been index via mapifno.
> the field is a text field
> Am I doing something wrong ?
> Jeppe
> here is the funktion that load the map and perform the search
> function FindExtendForMatrikel()
> 	global $GISREF_LAYER_NAME, $MAP_PATH_NAME, $MAP_FILE_NAME,
> $MATRIKEL_ID_NAME;;
> 	global $xmin, $ymin, $xmax, $ymax;
> 	global $MATRIKEL_LAYER_NAME, $starttid, $kort;
> 	$Shape_matr = array();
> 	$Result = mssql_query (&quot;select * from kort WHERE name = '&quot;.
> $MATRIKEL_LAYER_NAME . &quot;'&quot;);
> 	while ($row = mssql_fetch_array($Result))
> 		$Map = ms_newMapObj($MAP_FILE_NAME);
> 		$Layer = ms_newLayerObj($Map);
> 		$Layer-&gt;set('name', &quot;MatrikelSearchLayer&quot;);
> 		$Layer-&gt;set(&quot;connection&quot;, $row['MS_CONNECTION']);
> 		$Layer-&gt;set(&quot;connectiontype&quot;, MS_OGR);
> 		$Layer-&gt;set('status', MS_OFF);
> 		$Layer-&gt;set('type', MS_LAYER_POLYGON);
> 		$Layer-&gt;setProjection($row['MS_PROJECTION']);
> 		$Class = ms_newClassObj($Layer);
> 		$Class-&gt;set('name', &quot;Matrikler&quot;);
> 		$Class-&gt;set('template', 'void');
> 	foreach ($kort-&gt;objekter as $value)
> 		if ($value-&gt;ObjType() == &quot;Matrikel&quot;)
> 			$ID_value = $value-&gt;id;
> 			$Layer =
> $Map-&gt;getLayerByName(&quot;MatrikelSearchLayer&quot;);
> 			//$ID_value = &quot;78065110g&quot;;
> 			$ID_navn = $MATRIKEL_ID_NAME;
> 			$ResultType = MS_MULTIPLE;
> 			$Search_Str = &quot;&quot;;
> 			$matr_array = split(',', $ID_value);
> 			foreach ($matr_array as $matr)
> 			  	if ($Search_Str != &quot;&quot;) {
> 					$Search_Str .= &quot; OR &quot;;
> 				$Search_Str .= &quot; '[$ID_navn]' = '$matr'
> &quot;;
> .. $Search_Str .')', $ResultType);
> 			$QryRes = $Layer-&gt;getNumResults();
> 			if ($QryRes == 0 ) { $kort-&gt;matrikelsogning =
> NULL;}
> 			for ($I = 0; $I &lt; $QryRes; $I++)
> 			  	$Res = $Layer-&gt;getResult($I);
> 			 	$Layer-&gt;open();
> 			    	$Shape_matr[] =
> $Layer-&gt;getShape($Res-&gt;tileindex, $Res-&gt;shapeindex);
> 				$Layer-&gt;close();
