WCS from multiple netCDF returning only background image
Norman Barker nbarker at ITTVIS.COM
Wed Feb 28 12:25:19 EST 2007
Hi Ed,
Do 'gdalinfo filename.nc'
Then from the prompt try and find a string like this
SUBDATASET_1_NAME=NETCDF:"/my__ta_1982013118.nc":ta
Then do gdalinfo NETCDF:"/my__ta_1982013118.nc":ta
And you will see a bbox string.
So as per my previous email (not being sarcastic here, just don't want
to retype)
You need to put NETCDF:"...":ta in the location element of the dbf for
the shapefile.
I will dig out the python script I did this.  Or alternatively you can
use the perl script.  I used python since I could get the variable name
out in code.
Ping me if you need any help.
Thanks,
Norman
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of edfialk
Sent: 28 February 2007 17:15
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WCS from multiple netCDF returning
Hi Norman,
I am really grateful for the work you all have done with MapServer, and
I am
using a pearl script that was posted in the WCS Use Cases (by you, I
believe).
I believe I'm having a problem with creating the tile index.
After running gdaltindex, and then ogrinfo on the shapefile, all of my
layers (or files) look the same:
OGRFeature(RETRO_index):40
  location (String) = RETRO_anthro_nox_2000.0.5x0.5.nc
  POLYGON ((0 0,0 0,0 0,0 0,0 0))
--this is before running the pearl script so no time field yet.
Any idea why all the polygon coordinates are 0??
Again, thanks for all the help.
-Ed
View this message in context:
http://www.nabble.com/WCS-from-multiple-netCDF-returning-only-background
-image-tf3303314.html#a9208561
Sent from the Mapserver - User mailing list archive at Nabble.com.
