SLD troubles -desperate!
Edward Fialkowski wef1 at CEC.WUSTL.EDU
Tue Jan 2 13:10:05 EST 2007
I have been unable to get my WMS capable MapServer to recognize an sld
passed in through the url (SLD=http:...)
The sld is readable, I have tested it on an example from the SLD
documentation - i.e. written my own SLD and pointed to it from the example,
works perfectly.
I am totally out of ideas as to why I cannot get it to show up on my own
server.
I'll give as much information as i can, any help would be extremely
appreciated.
map file:
MAP
  NAME "All"
  STATUS on
  SIZE 800 600
  EXTENT -2200000 -712631 3072800 3840000
  UNITS METERS
  SHAPEPATH "/var/www/html/mapserver/mapdata/"
  IMAGECOLOR 220 220 220
  FONTSET "/var/www/html/mapserver/mapdata/"
WEB
  IMAGEPATH "/var/www/html/tmp/"
  IMAGEURL "/tmp/"
  METADATA
        "wms_title"     "All"
        "wms_onlineresource" "http://niceguy.wustl.edu/cgi-bin/mapserv.exe?"
        "wms_srs"       "epsg:4326"
  END
END
PROJECTION
        "init=epsg:4326"
END
LAYER
  NAME NAmer_bdr
  METADATA
        "wms_title"     "NAmer_bdr"
  END
  TYPE LINE
  STATUS on
  DATA bound_p
  PROJECTION
        "init=epsg:4326"
  END
  CLASS
        STYLE
          OUTLINECOLOR 0 0 0
        END
  END
END
SLD File:
<StyledLayerDescriptor version="1.0.0">
  <NamedLayer>
    <Name>NAmer_bdr</Name>
    <UserStyle>
      <Title>NAmer_bdr</Title>
      <FeatureTypeStyle>
        <Rule>
        <LineSymbolizer>
         <Geometry>
           <PropertyName>center-line</PropertyName>
         </Geometry>
         <Stroke>
           <CssParameter name="stroke">#00FF00</CssParameter>
         </Stroke>
        </LineSymbolizer>
        </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
and just in case:
[root at niceguy mapserver-4.10.0]# ./mapserv -v
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
Please, please any help.
Thanks!
-Ed
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070102/7c0f194a/attachment.html
