Problem with SHP files
antti siukola siukola.antti at GMAIL.COM
Wed Jan 3 05:15:20 EST 2007
Hi!
It seems that I have another kind of problem also. I have a shp-file
that doesn't get drawed.
This is how it is in map-file:
LAYER
        NAME "name"
        TYPE POLYGON
	STATUS ON
        DATA "/path/to/shp"
		CLASS
			NAME "name"
			# TEMPLATE
			COLOR 215 232 195
			#OUTLINECOLOR 0 0 0
		END
END
I can open the shp in quantum gis perfectly but mapserver doesn't draw it.
Antti S
On 12/15/06, antti siukola <siukola.antti at gmail.com> wrote:
> No. It's my own interface and I also render new images on every request.
> Antti
> On 12/15/06, Andy Freed <afreed at pdx.edu> wrote:
> > Are you using Ka-map or any other tiled interface for your map? You
> > may need to delete all the old tiles before the new shapefiles are
> > rendered.
> > Andy Freed
> > afreed at pdx.edu
> > http://web.pdx.edu/~afreed
> > On Dec 15, 2006, at 9:04 AM, antti siukola wrote:
> > > Hi!
> > > I'm having a problem with SHP files. I over wrote couple of SHP files
> > > but mapserver seems to render the old ones. I print labels from these
> > > shapes and the labels aren't updated. Is there a cache that I can
> > > clear?
> > > Thanks!
> > > Antti
