Problem with SHP files
Fawcett, David David.Fawcett at STATE.MN.US
Wed Jan 3 08:52:06 EST 2007
Have you tried STATUS DEFAULT?
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Bill Thoen
Sent: Wednesday, January 03, 2007 7:41 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Problem with SHP files
Is the native coordinate system the same as your map's? Yo umay need to
add a PROJECTION object to your layer. You can use ogrinfo to verify
that the coordinate system is as you expect.
On Wed, Jan 03, 2007 at 12:15:20PM +0200, antti siukola wrote:
> Hi!
> It seems that I have another kind of problem also. I have a shp-file
> that doesn't get drawed. This is how it is in map-file:
> LAYER
>        NAME "name"
>        TYPE POLYGON
> 	STATUS ON
>        DATA "/path/to/shp"
> 		CLASS
> 			NAME "name"
> 			# TEMPLATE
> 			COLOR 215 232 195
> 			#OUTLINECOLOR 0 0 0
> 		END
> END
> I can open the shp in quantum gis perfectly but mapserver doesn't draw
> it.
