MS4W and Oracle (spatial)
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu Jan 4 05:44:14 EST 2007
An Oracle 10 client can connect to a 9 database, no problem.
Are you unable to install the Oracle 10 client on your server machine? In
that case, you'll need to compile Mapserver yourself against the right
Oracle client, or get someone to do that for you.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Virginie BERRE <vberre at gi-paris.com>
Naar: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>,
MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Cc: aude.allain.ext at mappy.com
Onderwerp: RE: [UMN_MAPSERVER-USERS] MS4W and Oracle (spatial)
Datum: 04/01/07 08:39
> Hi Bart!
> My problem is that my oracle's version is 9.2!
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Bart van den Eijnden (OSGIS)
> Envoyé : jeudi 4 janvier 2007 11:24
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : Re: [UMN_MAPSERVER-USERS] MS4W and Oracle (spatial)
> See:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g
> Best regards,
> Bart
> http://www.osgis.nl
> Van: Virginie BERRE <vberre at GI-PARIS.COM>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] MS4W and Oracle (spatial)
> Datum: 04/01/07 08:22
> > Hi all !
> > &nbsp;
> > I need a windows version of
> > mapserver which supports oracle spatial dataset. Is it possible? And
how
> to do it?
> > &nbsp;
> > Thanks for your help!
> > Best regards,
> > &nbsp;
> > Virginie BERRE / Ing&eacute;nieur &eacute;tude et
> > d&eacute;veloppement
> > G&eacute;n&eacute;rale d&#8217;Infographie
> > ZA Les Erables &#8211; b&acirc;timent 4
> > 66 route de Sartrouville - 78232 Le Pecq Cedex&nbsp;
> > T&eacute;l.&nbsp;: (33) (0)1.30.15.40.50 &#8211;
> > Fax&nbsp;: (33) (0)1.30.15.40.60
> > mailto:vberre at gi-paris.com
> > http://www.generale-infographie.fr
> > P N'imprimez ce
> > message que si vous en avez l'utilit&eacute; &#8230;
