Mapfile WMS connection string parsing problem for layer names with dots/periods (".")
Havard Tveite havard.tveite at UMB.NO
Thu Jan 4 10:00:31 EST 2007
While editing the connection string for my email, I must have
removed too much.  Sorry!  The problem persists though.
The "LAYERS=" was there originally:
CONNECTION "http://wms.server.org/wms_test?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&LAYERS=TEST.TEST&STYLES=&FORMAT=image/png"
Produces the following in the mapserver log file (slightly edited...):
Thu Jan  4 15:46:17 2007,23090,127.0.0.1,test-wms,0,261498.765626 6621607.187500 262014.390626 6622122.812500,261756.578126 6621865.000000,test ,msBuildWMSLayerURL(): WMS connection error. MapServer supports only WMS 1.0.0 to 1.1.1 (please verify the VERSION parameter in the connection string). <br>
msOWSParseVersionString(): WMS server error. Invalid version (1.1.1&SERVICE=WMS&REQUEST=GetMap&LAYERS=TEST.TEST&STYLES=&FORMAT=image/png). OWS version must be in the format 'x.y' or 'x.y.z' <br>
while
CONNECTION "wms.server.org/wms_test?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&LAYERS=TEST_TEST&STYLES=&FORMAT=image/png"
Gives me an inimage exception ("LAYER with ID TEST_TEST does not exist")
from the WMS server, as expected.
To reproduce the error one should only need to create a map file
with a WMS layer and a connection string that includes a layer name
with a "." in it.
Regards,
Håvard
Rahkonen Jukka wrote:
> Hi,
> Maybe this is not the reason for your trouble, but shouldn't it in any case be
> &LAYERS=TEST.TEST? Now LAYERS seem to be missing from your URL
> http://wms.server.org/wms_test?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&TEST.TEST&STYLES=&FORMAT=image/png
> Regards,
> -Jukka-
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Havard Tveite
> Sent: Wed 3.1.2007 17:08
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Mapfile WMS connection string parsing problem for layer names with dots/periods (".")
> Daniel Morissette wrote:
>> Just looking at the error message it's not obvious what is really
>> happening. Could you share your full layer definition from the mapfile?
>> Also, which version of MapServer are you using?
> Sorry,  I am using:
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> OpSys is Solaris 2.7.
> Layer definition (real WMS server name and layer names removed):
>    LAYER
>      NAME "test-test"
>      MAXSCALE 5000
>      MINSCALE 500
>      METADATA
>        "wms_title" "Test"
>        "wms_srs" "EPSG:32633"
>        "wms_connectiontimeout" "200"
>        "wms_opaque" "1"
>      END
>      TYPE RASTER
>      CONNECTIONTYPE WMS
>      CONNECTION "http://wms.server.org/wms_test?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&TEST.TEST&STYLES=&FORMAT=image/png"
>      PROJECTION
>        "init=epsg:32633"
>      END
>    END #layer
> Håvard
>> Daniel
>> Havard Tveite wrote:
>>> I am experiencing problems with a WMS connections where
>>> layer names contain dots/periods (".").
>>> Whenever a layer name with a "." appears in the "LAYERS"
>>> parameter of the WMS connection string, mapserver has
>>> trouble parsing the connection string.
>>>  From the Mapserver log (connect string is:
>>> "http://wms.server.org/wms_test?VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&TEST.TEST&STYLES=&FORMAT=image/png"):
>>> (1.1.1&SERVICE=WMS&REQUEST=GetMap&TEST.TEST&STYLES=&FORMAT=image/png).
>>> If I remove the "." no parsing errors occur.
>>> Are periods/dots (".") allowed in WMS Layer Name?
>>> If so, is this a bug?
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 14, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt
