SLD troubles -desperate!
edfialk wef1 at CEC.WUSTL.EDU
Thu Jan 4 12:14:05 EST 2007
HURRAY! That did it.  Thanks so much everyone that helped.
All I did was recompile with --with-ogr=path and bam it worked.
thanks again!
-Ed
Yewondwossen Assefa wrote:
> Hi There,
>   OGR is also a needed library (for geometry conversions). Is it
> possible for you to test it with OGR enabled (USE_OGR flag) ? If that is
> the case I will update the docs to reflect it.
> Later,
> Edward Fialkowski wrote:
>> I have been unable to get my WMS capable MapServer to recognize an sld
>> passed in through the url (SLD=http:...)
>> The sld is readable, I have tested it on an example from the SLD
>> documentation - i.e. written my own SLD and pointed to it from the
>> example, works perfectly.
>> I am totally out of ideas as to why I cannot get it to show up on my own
>> server.
>> I'll give as much information as i can, any help would be extremely
>> appreciated.
>> map file:
>> MAP
>>   NAME "All"
>>   STATUS on
>>   SIZE 800 600
>>   EXTENT -2200000 -712631 3072800 3840000
>>   UNITS METERS
>>   SHAPEPATH "/var/www/html/mapserver
>> /mapdata/"
>>   IMAGECOLOR 220 220 220
>>   FONTSET "/var/www/html/mapserver/mapdata/"
>> WEB
>>   IMAGEPATH "/var/www/html/tmp/"
>>   IMAGEURL "/tmp/"
>>   METADATA
>>         "wms_title"     "All"
>>         "wms_onlineresource"
>> "http://niceguy.wustl.edu/cgi-bin/mapserv.exe
>> <http://niceguy.wustl.edu/cgi-bin/mapserv.exe>?"
>>         "wms_srs"       "epsg:4326"
>>   END
>> END
>> PROJECTION
>>         "init=epsg:4326"
>> END
>> LAYER
>>   NAME NAmer_bdr
>>   METADATA
>>         "wms_title"     "NAmer_bdr"
>>   END
>>   TYPE LINE
>>   STATUS on
>>   DATA bound_p
>>   PROJECTION
>>         "init=epsg:4326"
>>   END
>>   CLASS
>>         STYLE
>>           OUTLINECOLOR 0 0 0
>>         END
>>   END
>> END
>> SLD File:
>> <StyledLayerDescriptor version="1.0.0">
>>   <NamedLayer>
>>     <Name>NAmer_bdr</Name>
>>     <UserStyle>
>>       <Title>NAmer_bdr</Title>
>>       <FeatureTypeStyle>
>>         <Rule>
>>         <LineSymbolizer>
>>          <Geometry>
>>            <PropertyName>center-line</PropertyName>
>>          </Geometry>
>>          <Stroke>
>>            <CssParameter name="stroke">#00FF00</CssParameter>
>>          </Stroke>
>>         </LineSymbolizer>
>>         </Rule>
>>       </FeatureTypeStyle>
>>     </UserStyle>
>>   </NamedLayer>
>> </StyledLayerDescriptor>
>> and just in case:
>> [root at niceguy mapserver-4.10.0]# ./mapserv -v
>> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=GDAL
>> INPUT=SHAPEFILE
>> Please, please any help.
>> Thanks!
>> -Ed
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
View this message in context: http://www.nabble.com/SLD-troubles--desperate%21-tf2909232.html#a8163045
Sent from the Mapserver - User mailing list archive at Nabble.com.
