slow database
Jeppe Lund Andersen JXA at COWI.DK
Mon Jan 8 08:15:56 EST 2007
The database is the same
they have the same index's
Jeppe
> -----Original Message-----
> From: Fabian Rami [mailto:fabian.rami at wowcompany.com]
> Sent: Monday, January 08, 2007 1:58 PM
> To: Jeppe Lund Andersen
> Subject: Re: [UMN_MAPSERVER-USERS] slow database
> Have you build the same Index on your table ?
> Jeppe Lund Andersen a écrit :
> > Hello
> > iam running mapserver on a windows 2003 server.
> > I made an application that uses ODBC connection, when I run
> it on my
> > local machine that has sql installed it performance fast
> enough (takes
> > 2 sec to make the map), but if I has a connection to a sql
> that is on
> > another server the performance is not good (takes 20 sec to
> make the map).
> > it is the same database on both machines.
> > So is it a known fact that when using an external SQL server the
> > performance is slow ?
> > Med venlig hilsen
> > Jeppe Lund Andersen
