MapScript & ImageMap creation
David Martin David at ITBEYOND.COM.AU
Fri Jan 12 02:51:45 EST 2007
Hello,
I am trying to implement a MapScript function to simulate the ImageMap
creation with MapServer example.
I am using the MapScript C# system and implementing the code in VB.NET.
My goal is to build a new ImageMap class that will implement MapScript.
I have made the query run and return results however I am trying to work
out how to access the shapeObj bounds in terms of shpxy rather than
coords. I have returned the result in coords but cannot find how to
convert to imgxy. Is there an easy solution?
Regards
David Martin
Managing Director
I.T. Beyond Pty Ltd
Postal:
PO BOX 967
HILLARYS WA 6923
Ph:
(08) 9403 3737
Mobile:
0417 677 275
Fax:
(08) 9403 3738
Check out our websites: www.ExplorOz.com
<blocked::http://www.exploroz.com/>  and www.itbeyond.com.au
<blocked::http://www.itbeyond.com.au/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070112/ac9fe288/attachment.html
