[Fwd: Re: [UMN_MAPSERVER-USERS] symbols in mapfile or
symbolset file?]
Dolf Andringa
dolf.andringa at ELCYION.NL
Fri Jan 12 07:18:57 EST 2007
Ok, I have got it to work with a workaround. It is not very clean, but
it works :)
I first write the mapObj to a file
Then I read that file with python
I remove the last END statment
and then I add all symbol statements to it.
I add the END statement again at the end of the file and write it to
disk again. Then I create a new mapObj from that mapfile.
Script:
mpobj.save("tmp.map")
lines=open("tmp.map",'r').readlines()
lines[-1]=""
for s in symbols:
lines.append(s)
lines.append("\nEND\n")
open("tmp.map",'w').writelines(lines)
mpobj=mapscript.mapObj("tmp.map")
The symbols variable is a list of strings where each string is a symbol
definition like:
SYMBOL
NAME 'point5'
TYPE ELLIPSE
FILLED FALSE
POINTS
5.0 5.0
END
END
I know, it is not very clean but it works for now. I am really open to
better ways of doing this. :) Thanks,
Dolf.
Dolf Andringa schreef:
> Nicol showd be the link below as an answer to my question, which it
> would be if I was using PHPMapscript, but I am using the python
> mapscript module. the nomal mapscript API
> (http://mapserver.gis.umn.edu/docs/reference/mapscript/index_html) does
> not seem to offer this possibility. Is that correct? To me it would be
> very logical if you could just create a mapObj, then create symbolSetObj
> and then some symbolObj's, add the symbolObj's to the symbolSetObj and
> add the symbolSetObj to the mapObj. Just like you can create classObj's,
> add them to layerObj's, and add layerObj's to a mapObj. I am trying this
> to circumvent the problem I posted yesterday with the strange parsing
> error when adding a symbolset file to a mapObj.
> Hope somebody can help me with either of the problems.
> Dolf.
> Nicol Hermann schreef:
>> Dolf,
>> you can add symbols to the mapObj via mapscript. See e.g.
>> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/symbolobj
>> HTH Nicol
>> Am Donnerstag, den 11.01.2007, 14:07 +0100 schrieb Dolf Andringa:
>>> Yeah I know. THe question is just where I define them. When you
>>> normally use mapfiles you create a separate symbolset file with your
>>> symbol definitions and in the mapfile in the map description you add
>>> "symbolsetfile <filename>" or you directly put the symbol
>>> descriptions in the map description instead of in a separate file.
>>> I am not writing mapfiles though, I am creating maps using mapscript
>>> (and directly draw them). And mapscript does not give you the option
>>> to add symbols to the mapObj, it just gives you the possibility to
>>> add a separate symbolSet file to the mapObj. That is my point. When I
>>> manually write mapfiles, I have the option to either define my
>>> symbols directly in the map description or in a separate file and
>>> reference that from the map description. With mapscript I do not have
>>> that option.
>>> Dolf
>>> Kai Behncke schreef:
>>>> On Thu, 11 Jan 2007 13:28:59 +0100, Dolf Andringa wrote
>>>>> sorry, meant to send it to the mailinglist, not just Kristian.
>>>>> -------- Originele bericht --------
>>>>> Onderwerp: Re: [UMN_MAPSERVER-USERS] symbols in mapfile or
>>>>> symbolset file?
>>>>> Datum: Thu, 11 Jan 2007 13:28:13 +0100 Van: Dolf Andringa
>>>> <dolf.andringa at elcyion.nl>
>>>>> Aan: Thy, Kristian <Kristian.Thy at ATKINSGLOBAL.COM>
>>>>> Referenties:
>>>>> <CE2BE61DABB9384A934BD4E648DFDA37B7E86D at EXCVS1.rdg.bane.dk>
>>>>> Ok,thanks. I don't think it is possible to do this with mapscript
>>>>> though
>>>>> is it? It would be nice if there was an addSymbol method on the
>>>>> mapObj object in mapscript which allows you to add symbols to the
>>>>> map declaration. Or am I completely missing something?
>>>>> Dolf.
>>>> Hi Dolf,
>>>> normally you need to define symbols by yourself, or you use code
>>>> that other
>>>> user have produced.
>>>> One example to define it inside a mapfile:
>>>> SCALEBAR
>>>> STATUS embed
>>>> TRANSPARENT off
>>>> INTERVALS 4
>>>> SIZE 200 3
>>>> UNITS kilometers
>>>> COLOR 250 250 250
>>>> OUTLINECOLOR 0 0 0
>>>> BACKGROUNDCOLOR 100 100 100
>>>> STYLE 0
>>>> POSTLABELCACHE true
>>>> LABEL
>>>> COLOR 0 0 90
>>>> #OUTLINECOLOR 200 200 200
>>>> SIZE small
>>>> END END
>>>> # SYMBOLS USED IN PMAPPER
>>>> # - 'circle' always necessary (used e.g. for highlight)
>>>> # - 'square' used in currecnt map file
>>>> # Symbols can also be defined via tag SYMBOLSET (see above)
>>>> Symbol
>>>> Name 'circle'
>>>> Type ELLIPSE
>>>> Filled TRUE
>>>> Points
>>>> 1 1
>>>> END
>>>> END
>>>> Symbol
>>>> Name 'square'
>>>> Type VECTOR
>>>> Filled TRUE
>>>> Points
>>>> 0 1
>>>> 0 0
>>>> 1 0
>>>> 1 1
>>>> 0 1
>>>> END
>>>> END
>>>> #================== START OF LAYER SECTION =====================#
>>>> LAYER
>>>> NAME "jpl_wms_global_mosaic"
>>>> TYPE RASTER
>>>> STATUS OFF
>>>> CONNECTION
>>>> But in my opinion, if you have quite a lot symbols:
>>>> Use the symbolfile for it. Its cleaner,
>>>> Regards, Kai
>>>> Dipl.-Geogr. Dipl.-Umweltwiss. Kai Behncke
>>>> Institut für Geoinformatik und Fernerkundung (IGF)
>>>> Universität Osnabrück
>>>> Kolpingstr. 7
>>>> 49074 Osnabrück
>>>> Raum: 01/308
>>>> Tel.: +49 541 969-4450
>>>> E-Mail: mailto:kbehncke at igf.uni-osnabrueck.de Web:
>>>> http://www.igf.uni-osnabrueck.de
