JOIN object usage in a mapfile
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Sun Jan 14 10:58:22 EST 2007
Hello everyone,
For the first time I am trying to use the mapfile JOIN object, and I
can't seem to get it to work.  From the mapjoin.c file I can see that
DBF, CSV, PostgreSQL, and MySQL are supported.  I have personally tried
to view query results joined from DBF, CSV, and PostgreSQL tables
unsucessfully.  (my goal is to also update the sparse documentation for
this also on http://mapserver.gis.umn.edu/docs/reference/mapfile/join).
  Here is my DBF test case:
Test Environment
mapserver 4.10.0
windows
mapfile layer
LAYER
   NAME prov_bound
   TYPE POLYGON
   STATUS DEFAULT
   DATA prov
   CLASS
     NAME "Province"
     STYLE
       OUTLINECOLOR 120 120 120
       COLOR 255 255 0
     END
   END
   TEMPLATE "../htdocs/cgi-query-templates/prov.html"
   HEADER "../htdocs/cgi-query-templates/prov-header.html"
   FOOTER "../htdocs/cgi-query-templates/footer.html"
   JOIN
     NAME "test"
     TABLE "../data/lookup.dbf"
     FROM "ID"
     TO "IDENT"
     TYPE ONE-TO-ONE
   END
END # layer
ogrinfo
 >ogrinfo lookup.dbf lookup -summary
INFO: Open of `lookup.dbf'
using driver `ESRI Shapefile' successful.
Layer name: lookup
Geometry: None
Feature Count: 12
Layer SRS WKT:
(unknown)
IDENT: Integer (2.0)
VAL: Integer (2.0)
 >ogrinfo prov.shp prov -summary
INFO: Open of `prov.shp'
Layer name: prov
Geometry: Polygon
Feature Count: 12
Extent: (-2340603.750000, -719746.062500) - (3009430.500000, 3836605.250000)
Layer SRS WKT:
(unknown)
Template
<tr bgcolor="#EFEFEF"><td align="left">[NAME]</td><td
align="left">[VAL]</td></tr>
Query Results
Layer: Provinces
NAME	VAL
Ontario	[VAL]
Other Notes
- the join seems to be happening, because if I specify false FROM/TO
values errors are thrown, yet I cannot get values to appear from the
[VAL] field
- ID/IDENT are integer values from 1 to 12
- the join works with desktop GIS packages
Can someone see what I am doing wrong?
thanks.
jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
