MapServer Version
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Mon Jan 15 09:25:53 EST 2007
It looks like you have another mapserv.exe in your PATH, is that possible?
MS4W 2.2.1 contains MapServer 4.10.0.
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PD
F OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPP
ORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPP
ORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
INPUT=OG
R INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
By the way, MS4W has its own mailing list for these type of
configuration questions (join at
http://lists.maptools.org/mailman/listinfo/ms4w-users).
jeff
Zhonghai Wang wrote:
> Hi Guys,
> today I've doenloaded the new MS4W package ms4w 2.2.1.zip here:
> http://www.maptools.org/ms4w/index.phtml?page=downloads.html,
> but when I use -mapserv -v to check the version, it returns:
> MapServer version 4.8.3
> OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=WMS_SERVER SUPPO
> SUPPORTS=WCS_SERVER SUPPO
> RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL
> INPUT=OGR
> does that mean this package is not using the new MapServer 4.10.0
> source? Should I compile it myself from source code if I want to use the
> latest version?
> thanks for your information.
> Zhonghai
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
