Apache, SDE
Chad Ringenberg
chad at AGRIDATAINC.COM
Tue Jan 16 12:46:34 EST 2007
I struggled to get FastCGI working with mapserver but finally did using the steps below. However I'm having memory exceptions when using SDE layers anywhere from 3 to 15 map requests. I also tested against PostGIS and didn't receive any exceptions for the first 40 requests but the mapserv.exe did gradually consume more memory. I'm not sure if the configuration I used below is the best, but it's all I have found so far. Is there a different configuration I could use that would work more reliably on Windows 2003 server with SDE?
- Installed Apache version 2.0.59, this appears to be the latest version to work with mod_fastcgi.
- I downloaded mod_fastcgi http://www.fastcgi.com/dist/mod_fastcgi-2.4.2-AP20.dll and placed it in the cgi-bin directory.
- Placed my compiled (FastCGI enabled) mapserver in the cgi-bin directory.
- Added the following lines to conf.httpd in Apache.
- LoadModule fastcgi_module cgi-bin/mod_fastcgi-2.4.2-AP20.dll
- AddHandler fastcgi-script .fcgi
- FastCgiServer cgi-bin/mapserv.exe
- added the following to each layer in the map file: PROCESSING "CLOSE_CONNECTION=DEFER"
Thanks,
Chad
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Thursday, January 11, 2007 2:21 PM
Subject: [UMN_MAPSERVER-USERS] Apache, SDE
I have Windows 2003 server with the latest release of Apache and Mapserver
compiled with SDE(9.1) support. I am able to generate a map with the SDE
layers but the following errors are showing up in the Apache error.log.
[error] [client 127.0.0.1] msSDELayerOpen(): Layer seclayer opened from
scratch.\r
msConnPoolRegister(seclayer,192.168.5.5,port:5153,abc,user,***,01A12CA8)\r
[error] [client 127.0.0.1] msSDELayerOpen(): Layer seclayer specified
version SDE.DEFAULT.\r
Ultimately I'm trying to get FastCGI working but have been unable to and I'm
wondering if this may be why.
Thanks,
Chad
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070116/5cbffacc/attachment.html
