broken query
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Jan 17 16:29:57 EST 2007
Hi John, so in the busted app you see the []'s in the output? If that's
the case then
there's likely a mismatch between tag and attribute names. The names
are case
sensitive, that is you access attribute FOO through the tag [FOO].
Let me know if that doesn't help and I'll try to help more.
Steve
>>> "John B. Churchill" <jchurchill at AL.UMCES.EDU> 1/12/2007 9:19:28 AM
I'm still working on modifying the basic ITASCA DEMO. I got some
queries to work in one application (returns data from the dbf table)
but
they aren't working correctly in another (returns a table that looks
like the static template file without any data).
In both I have followed these steps:
1. Created Templates in the "templates" folder named after the layer
and with the appropriate fields in square brackets [].
2. put a statement in the MAP file at the end of the layer block that
refer to the html file in step 1 like so ...
TEMPLATE "templates/anti_bnd.html"
Are there other steps that I need to follow. If so I must have done
them in the first case but forgot about them in the 2nd case. Any help
on this is appreciated.
J.B.
John B. Churchill,
M.S. http://alx.al.umces.edu/~jchurch/
GIS Specialist (301) 689-7109
University of Maryland Center for Environmental Science
Appalachian Laboratory http://www.al.umces.edu/
Education http://alese.al.umces.edu/
301 Braddock Road
Frostburg, MD 21532
FAX - (301) 689-7200
