Mapscript 4.10/Oracle Spatial : GetShape and drawQuery problems
Aude Allain
aude.allain.ext at MAPPY.COM
Thu Jan 18 03:51:54 EST 2007
Hello,
Since I have installed the ms4w package, version 2.2.1, to have a
compiled mapscript dll which supports oracle spatial, I have some
problems with class methods.
I use:
- ms4w : php/mapscript_4.10.dll, php 5.2, Apache 2.2
- Oracle Database 9.2
- Oracle Client 10g
1. GetFeature
I have posted a message, without response to date, about the getFeature
function. When I use it, I get the following error : Fatal error: Call
to undefined function getFeature(). I use it because getShape() is
deprecated. And if I get shapeObj with getShape function I always get a
null object.
My code :
$layer = $map->GetLayerByName
($tab_layers[$i]);
$selectedObj = @$layer->queryByPoint($geoClic,
MS_MULTIPLE, 1);
$nbSelectedObj =
$layer->getNumResults();
if ($nbSelectedObj == 0)
continue ;
$layer->open();
$tabAttName = $layer->getItems();
$nbAttL =
count($tabAttName);
for ( $j=0 ; $j<$nbSelectedObj ; $j++)
$object =
$layer->getResult ($j);
if ( $object == null ) echo
"<br>objet NULL ";
//$shapeObj =
$layer->getFeature($object->shapeindex);
$layer->getShape($object->tileindex,$object->shapeindex);
In each class of my mapfile, there is the line TEMPLATE
"ttt_query.html".
2. queryByAttributes
I call this function to get the object which has the 'ID' field and has
the value '10400300001265'
$res = $layer->queryByAttributes'ID', 'ID=10400300001265', MS_MULTIPLE);
This call works, it permits to select the object in the layer because
$layer->getNumResults() return 1.
Then, I want to display the result so I execute the DrawQuery function
on my map Object. And the returned imageObj is always null.
Could you help me ?
Aude
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070118/d9a145f3/attachment.html
